Question about Samsung SCX-4216F All-In-One Laser Printer
Black lines when receiving fax copies. How do I clean mirrors?
  • 73 Answers
You should check you cartrige for stucked tonner in it. You may use thin object to push those toner parts back. Moreliked cartridge should be replaced.
Posted on Sep 28, 2009
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying!
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Brother 5750E Fax
When I fax it copies a black line is on the page. And when I copy from the top part it copies a black line. How can I fix that?
are you getting black lined copies while you are trying to send a fax or black lined images are obtained at the receiving end. Is there any problems while copying from platen glass. if it's ok, then check if there is any thing on the stream reading glass (the small sized glass plate meant for ADF) & clean it.
Apr 14, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
My fax type hp laserjet 3015 display a very big line (blanket of line) on the right hand side of the paper, and the left hand side is normal. This problem is observed in the received fax and during...
The mark is not being produced from the toner cartridge or scan mirror. The line is being produced by the Drum unit. You need to replace it.
You can purchase one online or at you local stationery retailer.
Hope this helps.
Best regards,
Dave
Please vote if this helped
Nov 26, 2010 | Brother IntelliFAX 2800 Laser Fax
When making a copy on the fax machine, it has a la...
your must clean scan unit ,mirrors and check drum .make a white copy if the problem occurs change drum unit
May 20, 2010 | Brother IntelliFAX 4100 Laser Fax
I have a Brother Fax 2850. When I send a fax the receiver has advised me that there is a vertical black line approx 2'' thick which blocks out some wording. How do I fix this?? Many Thanks Heather
Something is jammed in or covering the optics.
Check the area where the original document is placed for faxing.
Open this area and clean any liquid paper, sticky tape or staples covering the optics.
Test by making a copy. When the black line on a copy goes away the unit is fixed.
If the receiver is still getting this black line then it is probably their machine and not yours.
Send a fax to this number. 1300 368 999 It will send you back a copy of what it receives.
Nov 17, 2009 | Computers & Internet
On sending a fax the receiver copy has a black
You must clean the glass strip that the origional passes over to be scanned. You may have White-Out or an Ink smuge on it. Another way to determine if it is your FAX is to put in an original and make a copy. If the line is on your copy than it is your scanner **** (glass).
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
Receiver end of faxes shows vertical black line. I changed drum and toner also cleaned glass scanner. I do not have a glass flatbed scanner only an automatic feeder.
The cause of this problem is usually a dirty scanning glass (there might be ink or white out on the glass). Check the glass really closely or the cause could be dirty optics or a bad CCD board. There are mirrors underneath the scanning glass. Dirty optics can cause lines when faxing or copying. If you can not access these mirrors, they would have to cleaned by a technician.
Sep 08, 2009 | Brother MFC 4350 All-In-One Laser Printer
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
POOR COPY QUALITY
Here is the scoop! There are two (2) components to the fax machine, one is the scanner portion which is located just past where the paper you are copying or faxing enters the machine, separate the two sides and access the imaging plate, clean this area with denatured alcohol.
Step two is to clean the toner and drum unit, get the mirror at the back of the toner and under the toner. If after this you are still getting lines on the prints you will have to replace the drum unit KX FA-84 about $85. Happy faxing, Ken
May 15, 2008 | Office Equipment & Supplies
Even vertical lines on fax/copy
TYPICALLY SF900 FAX USES A DIFFERENT CIS SCANNER , THSI SORT OF INDICATION IS EITHER SMPS BAD OR CIS SCANNER BAD. HAPPY FAXING OMNIRESENT
Sep 16, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
Samsung SCX-4216F All-In-One Laser Printer Logo
78 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
