Zanussi FJS1225W Front Load Washer
Problem for Zanussi FJS1225W Front Load Washer
When spinning very loud
By williamdoyle on Sep 28, 2009
when spinning very loud before very silent
Solution #1
posted on Sep 28, 2009
Not Rated)
GodBlessU
Rank: Guru  Washers & Dryers  Expert
Rating: 85%, 159 votes
Since you say that before it was silent and these days you see loud noise while spinning I would first recomend to see the correct balance of the cloth you put in. Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Also Either you put something like a screw or a nail in with the washing, which will travel through the drum holes and scrape on the fixed drum. Check in case anything is left in a hole.
Or the bearing which the drum rotates on is shot. If you lift the front edge of the drum up and down by hand you may find excessive play due to bearing wear (a small amount of movement is normal), or rotate it by hand to confirm the noise.
Bearing replacement is acually quite easy for an average DIY person. You can get the bearing and water seal from either the maker or a good w/m spares shop (yellow pages). The tools needed are crosspoint screwdriver, and a socket set.
Thanks for contacting Fixya.
Was this helpful?
Yes
No
Popular Solutions for Zanussi FJS1225W Front Load
Questions and Unsolved Problems for Zanussi FJS1225W Front Load
Do you recommend Zanussi FJS1225W Front Load Washer?
Answer
Answer
Hiya my grandfather think the problem is the motor, but it does not spin. it turns on, drains the... (More)
Answer
zanussi fls 1383w program cycle keeps clicking round and stops on A sometimes it works but mostly it... (More)
Answer
zanussi jetsystem 1200xc fj1254w - door interlock came on as soon as door was closed. will allow... (More)
Answer
The LED display disappears and the cycle stops. I have to press the green start/pause button to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , CO
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
