Question about EliteGroup K7AMA Motherboard
CMOS SETTING The clock in CMOS does not running, and I cannot set it,please help me
  • 108 Answers
May be battery is dead replaced battery and check. below screen shotCMOS SETTING - f6376c8.jpg will help you to locate it.
good luck!
Posted on Dec 18, 2007
Why does the sony HDR-SR11 keep resetting the date and time?
probably need to replace cmos battery as it is probably not holding charge therefore not keeping internal clock going ,every time you restart it goes to it original clock setting when made as default time.
Jul 24, 2014 | Compaq CMOS Battery
Inspiron laptop clock occasionally reverts to July 2008
There is a small 3 volt battery on the motherboard which is the backup for the circuit clock .So if the battery has gone low in voltage the clock will be reset as the CMOS setting will be reset. The clock will then go back to the time of the laptop set-up which is in july 2008.
Replacing and then correcting the CMOS set- up on booting will set the clock to work to the current time/date.
Sep 16, 2011 | Dell Computers & Internet
Every time I turn it on, I have to reset all setting, It will not save setting after it is turned off. I.E clock, and date: some times wireless settings depending on how long it was off. Cmos batterie?
YES. The CMOS battery (complementary metal-oxide semiconductor) is low off charge or dead and needs to be replaced.
The CMOS typically is a battery-powered memory chip in your device that saves information needed at start up (before any software or program will run). If the battery is low of charge or is dead, you will eventually lose your personal settings and even some factory settings. The CMOS battery can be discharged if you have not used your device for long time.
Hope this helps.
Jun 25, 2011 | Sharper Image Literati Reader 16375680042...
Cmos setting wrong on start up
are you able to enter the cmos to make changes?
depending on the brand, you may hit one of several keys to access the cmos. del, f2, f10, f11, f12.
then try resteseing the cmos to defaults.
Jan 06, 2010 | Intel Computers & Internet
Date keeps reverting to 10/08 and clock won't keep time
i donno much........ may be ur comp inbuilt[battery used 4 time setting] battery would hav run out....... i think so
May 11, 2009 | Compaq Presario 1275 Notebook
Clock not keeping correct time
The CMOS battery keeps the laptop configuration stored in the CMOS chip and the main battery has no effect on the CMOS.
If the date and time drift off, it indicates the CMOS battery is nearly flat and needs to be replaced.
If you had ticked the Daylight saving box in the Time Zone tab in Control Panel - Date and Time setting then the time would automatically adjust for Daylight saving.
Apr 05, 2009 | IBM ThinkPad T40 2373 Notebook
Hi! i have a susu p5gcmx/1333 mother board. The error message is 'after post the- cemos setting wrong fatal error system holted'. but in this time if i press restart switch system rum normaly. what the...
CMOS settings retain data such as system clock, CPU and FSB speeds and so on. That error can come from a bad CMOS battery. This a circle batteries easily found on your mainboard and can purchase at almost any retail store.
Jan 16, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
OVERCLOCKING FAIL/CPU FAN ERROR
First approach shold be the CMOS utility, check in FAILSAFE DEFAULTS that the error settings for shutdown are either null for overclocking or disabled if you don't have the failsafe defaults on your CMOS utility then set your settings to best performance (should be found on the main page of the CMOS utility). If you are unsure of touching the CMOs then you could try to remove the CMOS battery (small 3 volt battery about the size of a 20 cent coin) located on the motherboard this should reset the CMOS and fix the problem. hope i could help,thanks:)
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Cmos settings
configure first the cmos setting by means of pressing f8 while booting. then press the load optimal setting and save it.
Apr 28, 2008 | EliteGroup P4VMM2 Motherboard
EliteGroup K7AMA Motherboard Logo
61 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
