Question about Ryobi Cultivator
Fuel pipe broken - Ryobi Cultivator
  • 3,740 Answers
If it is just the fuel line go to any lawn mower repair shop and get a piece of bulk fuel line and replace it. If it is the fuel primer bulb and tube here is the manual
http://www.oscar-wilson.com/MANUALS/BOLENS/21B-121R765.PDF
See item 8
Posted on Jan 29, 2010
There is no gas comeing from tank. Are the lines broken?
More likely the tank is dry or the petcock is faulty. If the lines were broken you would have gasoline pouring out. If the pipes are plastic on whatever it is you have, if you are using ethylene additive fuels, they damage the lining of the pipes and seal them up. You need to use ethylene safe fuel lines.
May 26, 2018 | Garden
Son ran it out of fuel ,put fuel in ,will crank wont run ,lots of air in fuel lines have bled at injector pump and injector ,changed filters ,
you need to ensure the connection between tank and pump is absolutely clear of air and tank bottom debris. (I am guessing the vehicle is diesel?
Ensure there is plenty of fuel in the tank to circumvent the introduction of more air.
Check that the pump is actually pumping fuel and had not broken
If it is connect the fuel pipe but disconnect from the engine end.
Crank engine until fuel arrives then stop cranking and connect pipe ensuring some fuel is left in the pipe. Connect it securely to prevent air ingress.
Get another vehicle with jumper leads to give you a boost. Connect up the cables with both engines stoppd, (yesm I know,) otherwise the vehicle can suffer alternator rectifier damage.
The second vehicle should then start and the engine revs held at a fast idle while the broke vehicle cranks over.
You should do this even if the broken vehicle has a good battery.
As the fuel is pumped through the air should be bled... ensure that no air is introduced at the rail/injectors.
It should, eventually , work. The fuel will absorb some air but if there is lots of it in the system the vehicle just will not start.
Making sure the fuel is clear of air upto the injector rail may help you to get it started.
GOOD LUCK (I hope it is a diesel!!!)
Jun 26, 2015 | Cars & Trucks
2002 chevy tahoa 5.3 codes p0171 0174
Trouble Code: P0171
Fuel Trim System Lean (Bank 1)
Possible Causes:
Air leaks in intake manifold, exhaust pipes or exhaust manifoldFuel control sensor is out of calibration (ECT, IAT or MAF)Low fuel pressure (fuel filter clogged, pressure regulator failure)One or more injectors restricted or pressure regulator has failedHO2S element is contaminated, deteriorated or has failedVacuum hose is disconnected, broken, leaking or loose.Trouble Code: P0174
Fuel Trim System Lean (Bank 2)
Possible Causes:
Dec 27, 2012 | Cars & Trucks
P0171 AND P0174B WHAT DOES IT MEAN?
Trouble Code: P0171
Possible Causes:
Air leaks in intake manifold, exhaust pipes or exhaust manifold.Fuel control sensor is out of calibration (ECT, IAT or MAF.)Low fuel pressure (fuel filter clogged, pressure regulator failure).One or more injectors restricted or pressure regulator has failed.HO2S element is contaminated, deteriorated or has failed.Vacuum hose is disconnected, broken, leaking or loose.Trouble Code: P0174
Possible Causes:
Air leaks in intake manifold, exhaust pipes or exhaust manifold.Fuel control sensor is out of calibration (ECT, IAT or MAF).Low fuel pressure (fuel filter clogged, pressure regulator failure).One or more injectors restricted or pressure regulator has failed.HO2S element is contaminated, deteriorated or has failed.Vacuum hose is disconnected, broken, leaking or loose.
Oct 24, 2012 | 1999 Chevrolet Express
My Husqvarna 24C fuel pipe in the fuel tank has perished and broken can I replace it and if so how?
Fuel lines are a push/pull fit, the fuel line has 2 flanges, one should sit either side of the fuel tank. I will send you a link to the parts manual.
May 31, 2012 | Husqvarna Forest & Garden 125l 18" Gas...
B&S fuel feed pipe connector problem
Try using an easy out (special tool for undoing broken threaded tubes and fittings) or a flat blade screwdriver and stick it into where the broken part is. Try to unscrew whats left of the broken tube.
Sep 17, 2017 | Briggs Motorcycles
Hi I have a Husqvarna 136 chainsaw the fuel line seems to have seperated/broken off inside the fuel tank. I can not see any place to reconnect it anybody have any ideas
The fuel hose is all one piece from the tank up to the carb, it is just an interference fit in the tank, you will need to replace the complete pipe, the best way to do this is to **** the new pipe up the middle, about 30/40mm, take away one side of the pipe, it will now fit through the hole in the tank from the top, use a pair of long nose pliers through the fuel filler hole to grab the pipe and pull it on in, trim the end and re fit the fuel filter.
May 10, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Fuel is running out on the ground from near the firewall, at the center area of the motor. It's not the pump, but I'm not sure it is the fuel pressure regulator either. Any way to tell without pulling...
it has been a while since i worked on one of those, but if i remember correctly there is a metal fuel pipe underneath the car that changes to a rubber pipe in that area. it can be checked quite easily from underneath the car. if you can raise the car SAFELY or get under it in a pit, you should be able to see where the fuel is coming from. the chances are it is a broken pipe or loose connection rather than a component failure
Feb 23, 2011 | 1994 Mazda 929
No2 fuel injector pipe keeps snapping! why?
One of the retainer clips is probably broken and letting the line vibrate. Install new retainer clips and that should stop the snapping. This also happens a lot on Mercedes Benz diesels too.
Feb 28, 2010 | 1997 Volkswagen Eurovan
Ryobi Cultivator Logo
277 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
