Question about Dell Dimension 1100 PC Desktop
My Dell Dimension 1100 will not power up there is a flashing amber power light on the front,the fans are working and the PSU is buzzing quite noticeable, any help would be much appreciated. Buggane
  • Buggane Sep 28, 2009
    Hi
    the screen does not power up either, just blank.
    Regards
    Buggane
  • alexeynayko May 11, 2010
    What you see on the screen
    Problem Solver:
  • 16 Answers
Re insert the ram and try again, clean the ram slot also
Posted on Sep 28, 2009
Flashing amber light
Hi, on most Dells a flashing amber light on the power button indicates a problem with the PSU or a short on the main power rail, if this is the case you should have 2 flashing lights as well, 1 & 3.
May 05, 2014 | Dell OptiPlex 3010 MT Desktop Computer
Amber light is flashing on my computer and it won't turn on at all. Help!
The Dell Dimension 300 gets the amber blinking light when there is power to the computer (the power supply) but the motherboard isn't getting the correct power. Sometimes it can indicate a motherboard fault or that the power supply is not set to the correct incoming voltage.
Check the back of the computer. If the power supply has a switch for incoming voltage, make sure that it matches your incoming voltage. Next check that the main power cable (20 or 24 pins depending on the computer) is fully seated on the motherboard. (It can only be connected one way and should lock onto the connector on the motherboard.)
Next check that the power supply is providing the correct power. You can simply install another power supply (known to work on another computer). Make sure that the PSU is correctly sized for the computer components. Alternatively use a multimeter or a dedicated power supply tester or put it in a different machine.
If the problem is not cured with a new PSU, the motherboard has a failure. Unfortunately, it's difficult to identify the exact bad component. (If a major component other than the CPU on the motherboard had failed, the diagnostic lights or beep codes could help identify the issue.)
I hope this helps.
Jun 10, 2012 | Dell Dimension 3000 PC Desktop
Computer acts like it in standby mode will not power up, made a weird noise according to my daughter and quit
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 23, 2011 | Dell Dimension 4400 Power Supply ** FREE...
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
My dell dimension b110 quit working one day and just flashed an amber colored light. I was told I need to replace the power supply. Is any 400W 20+4-pin ATX PSU w/SATA compatible?
Yes, just make sure it's ATX (not ATX mini etc but you'd see from the connector anyway) has the right motherboard connector and all other connectors. Also I'd go for a 450W as if your 400w died it may have been from a power surge that a 450W or higher would handle better.
Oct 29, 2010 | Dell Dimension™ B110 PC Desktop
Dell dimension 2350 won't boot, the psu fan comes on and the fan for the heatsink, the hard drive makes so noise what so ever and the disk drives won't open at all.
Depending on the Power and Diagnostic LED indications the system appears to be in a no post state. If the power LED is flashing Amber, the power supply is suspect. Solid Amber, indicates a motherboard problem. The Diagnostic LEDs on the back marked ABCD can give more specific POST error details.
Mar 05, 2010 | Dell Dimension 2350 PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
Dell Dimension 1100 PC Desktop Logo
211 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
