Washer wont drain after wash,spin wont work and makes grating noise?
  • 3,600 Answers
Your water pump has gone bad and the belt or gear drive hs malfunctioned. If it'sa belt it has broken and the water won't pump out. you can remove the back cover and see it it is spinning and the pumps are clear so you can see if water is pumping and the pulley is moving. That will give you and ideal if it's bad or not. But need the brand and model number t help you.
Posted on Sep 28, 2009
    Brigadier General:
  • 3,513 Answers
This is a very common problem. This could be caused by the filter being blocked - so give it a clean. It could also be the outlet water pipe being blocked - so give it a clean.It could also be the drain motor befing defective - so it will need replacing.
Thanks for contcting Fixya.com
Washer wont spin but makes loud noise
-could be a belt failure or some washmachines are directly coupled to the motor. - the coupling or belts are easliy replaced and visible if failed
Jan 12, 2012 | Washing Machines
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
Washer wont spin, makes a noise ,that the belt is not on
heatman101
Sep 30, 2010 | Kenmore 27612
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Not spinning
from recent experience could be a blockage in drain pipe or pump body. These can be detached and checked from the rear of the machine.
Jan 06, 2009 | LG WD14311RD Front Load Washer / Dryer
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
