Question about HP Computers & Internet
I get 1 long 2 short beeps when I start up, I know it is the video card, if I keep on trying I eventually get the screen working, and the laptop wrks ok but if you have to re start then it can take up to twenty minutes to get it running again. Is there any thing that can be done, apart from replacing the motherboard.
  • HP Master
  • 32,281 Answers
The video card on the laptop most likely uses part of the RAM memory module. Try reseating the RAM modules to see if this fixes the problem. If it doesn't then the RAM maybe partly faulty, remove the RAM modules and take it to your friendly computer shop and get them to test your RAM.
Posted on Sep 28, 2009
    Guru:
  • 441 Answers
I had the same problem with my HP. After a long struggle had to eventually replace the video card/chip. Luckily mine was still under warranty.
Cheers.
Please rate.
2 short then 1 short beep
It may indicate error or issue with Video Card.
If you can open and reset VC or try resetting the RAM.
Jul 15, 2015 | ASUS N53SV-XV1 Versatile Entertainment...
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
Any help for beeping acer laptop when opening..thanks
g'day!
i would like to know how many and the kinds of beeps? there are what they call beep codes which indicates what kind of problem the your laptop is experiencing: here are the common ones:
0 beep = no power, loose card, short
1 short beep = normal,POST (Power On Self Test), your computer is ok
2 short beeps = POST error, review screen for error code.
continuous beeps = no power, loose card, short
repeating short beeps = no power, loose card, short
1 long, 1 short beeps = motherboard issue
1 long, 2 short beeps = video issue
1 long, 3 short beeps = video display circuitry
three long beeps = keyboard/keyboard card error
one beep, blank, incorrect display = video display circuitry
aside from the 1 short beeps, you need to take your laptop to a technician to have it looked at.
cheers mate!
jelo a.
Aug 21, 2011 | Computers & Internet
Laptop Beeps on start up 1 long and two short beeps
You've checked the memory board/card, but have you tried using another memory card? The 1 long followed by 2 short beeps indicates that there's a problem with the memory card. Try to remove the memory card, then wipe the gold traces with a dry cloth and put it back in.
If you try replacing the memory card but you get the same problem, then proceed with the video card.
Aug 29, 2009 | HP Pavilion dv9000z Notebook
Hi my laptop will light but, three beeps, one long and two shorts
This error code is saying that either the RAM or video card has stopped working. Before replacing anything try reseating the components. If that does not work then start with a replacement video card. Video is more likely to fail than RAM. Good luck.
Apr 27, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Problem with ibm thinkpad r40
The IBM beep code error 1 long 2 short beeps means there is a video card fault. Reseat your RAM because the video card uses some of the RAM. If it doesn't work then the video chip on the motherboard is faulty, the only way to fix is to replace the motherboard - this may not be a cost effective solution.
Connecting an external monitor to the laptop won't work because the video card also sends data to the video port.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
Computer beeps when I try to start up
No Beeps
1 Short Beep
2 Short Beep
Continuous Beep
Motherboard issue.
Three Long Beeps
Jan 05, 2009 | HP Computers & Internet
Beep code
The sequence of one long beep and two short beep when starting computer usually means problem in your display adapter. Make sure your VGA connector is connected properly to VGA out port.
If you are using VGA card (non on-board), you might want to make sure that the card is inserted properly to motherboard.
The beep indicates that system can not initialize display.
Dec 15, 2008 | HP Pavilion dv9000z Notebook
Video card
Working and Working properly are 2 different things.
Unplug your pc. Let it set for 1 minute.
Plug in your pc.
Press the power button.
Does your monitor do anything?
No? Then it doesnt work
Yes? Then it works
If you get any video such as your BIOS or WIndows loading then the video card is fine.
Also, if you boot and you hear noises like:
Long Beep short Beep short Beep short Beep
(Long short short short)
Then your pc is not detecting the video card.
Oct 12, 2007 | Sony VAIO PCV-V210P PC Desktop
Computers & Internet Logo
52 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
