Green noise in black areas of picture
I have an Akai 37" LCD TV. It has been working fine for 2 months, and now I have green noise in areas of the picture that are supposed to be black. It doesn't cover the whole black area, but it is in a constant state of flux. The screen used to be blue in between switching channels, but now it turns green in between channels. Is it my tv or the cable line?
Thanks in advance for any help you can provide.
  • ian799 Mar 08, 2008
    I have a Sharp Aquos LC-37GD9 18 months old with green noise in black areas. This suddenly happend while watching. it is unwatcherble.
I'm sure you all thought of this but if someone does not state the easy fix then the easy fix doesn't get done.
I had the same thing happen to my Sam46inch1081, it just started doing it, no slow fade in over time.
I have cable with the HD box, all I did to fix it was unplug the power from the back of the hdbox, wait a few seconds plug power back in and have it reboot. Problem was solved.
Like I said, easy fix for me, don't know if this will help you, but ya never know.
Just thinking out loud here but maybe its not your tv but some other equipment you have added to it other than the hdbox.
Posted on Dec 23, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from
Samsung LCD Loud Noise and Green Vertical lines at Start up ... > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
TV picture goese black and white
Check your cables on the back of the TV and cable box. You either have it connected wrong, or they are loose. If you are using red green and blue, make sure that you are tightly in the red green and blue connectors. If you are using yellow white and red, then make sure you don't have the yellow in the green spot.
Mar 20, 2013 | Dell W3706MC 37 in. LCD HDTV
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Televison & Video Logo
478 people viewed this question
Top Televison & Video Experts
