Question about Dewalt DPD3100 Gas Pressure Washer
Where do you install a suction tube on dpd3100. I recieved the wrong manual with mine.
Where do you put attachments to make them work?
There is a button on the handle that releases the suction tube from the floor brush housing. Once the suction tube is released from the brush assembly, you can install the attachments on the suction tube.
Nov 15, 2015 | Dyson DC14 All floors Bagless Upright...
Central vac not sucking
Check for a plugged tube in the wall by listening to the motor when it's running. If it sounds like it's running too fast then there's an obstruction. If it sounds ok, then there's a disconnected tube somewhere in the system.
Sep 11, 2014 | Broan-NuTone CV353 Central Vacuum
There isNo suction on Kirby sentria
  1. Put the hose and see if suction is good. If it is - you may have had nozzle installed wrong or brush roll may be worn out (bristles must be sticking out of the nozzle by about 1/8 of an inch).
  2. If there is no suction with the hose either - check if bag is not overfilled to the point where dirt is blocking the fill tube hole.
  3. If two above are fine - something must be blocking the air passage from the fan to the bag. Check for clogs in the fill tube (tube inside the cloth bag) and mini emptor (bag bottom plastic part) and also see if there is something blocking the exhaust on the vacuum. You may not even see it so use a piece of wire. Once I found a sock there and it was so close to the fan that I could not see it in the hole and was only able to get it out using a homemade hook made from a coat hanger.
how to check for a clog in your Kirby
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 28, 2014 | Kirby Ultimate G Bagged Upright Vacuum
How do I fix suction on kirby sentria upright vaccum
www.goodvac.com
1-800-775-6586
May 20, 2014 | Kirby G3, G4, G5, G6, Ultimate, Diamond,...
Burning smell when switched on
if it is belt driven then your belt needs to be replaced, thats what was wrong with mine, but mine was too old to find a belt for so i just bought a used one at a fleemarket but hopefully thats your problem and if its not then its in the wireing if so i'd be looking for a new one, hope this helps, Jamie
Dec 14, 2012 | Sebo Automatic X1 Bagged Upright Vacuum
How do I drain transmission fluid (2000 sable ls(dohc))?
On an automatic tranny, the tranny oil pan is removed to drain the tranny fluid - a somewhat messy job. Typically when this done the tranny filler is replaced. A new pan gasket is installed in this procedure.
On the manual tranny, there is a drain plug at the bottom side of the tranny to drain the oil.
I have used a home made setup using a suction pump with small diameter tubing to **** the fluid out from the tranny filler tube. This is when I was replacing the filter and I dropped the pan. I did the suction routine to avoid all that fluid dripping out when you loosen the pan.
Have you located the leak? Is it from the tranny oil pan or maybe from a tranny cooler line?
Aug 10, 2009 | 2000 Mercury Sable
My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Jul 05, 2009 | Dewalt DPD3100 Gas Pressure Washer
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Panasonic mc-v6840 Low suction.Changed bag and cleaned hose blockage
Check the sole plate where the roller brush is. There may be an obstruction leading from the sole plate to the main dirt channel. Usually on many Panasonic uprights the main dirt channel is a removable bent plastic tube before it meets the bottom of the hose. Check to see if this isn't obstructed. ALso check your filters on the vacuum as sometimes a blocked filter means a lack of suction.
Jul 04, 2008 | Panasonic Vacuums
Suction
Don't panic! Easy fix!
I was having the same problem, but I removed the base plate from the bottom of the vaccum (5 screws on mine), revealing the roller and the engine. Just behind the roller is an intake tube. Mine had a piece of wrapping paper stuck in it causing everything else to clog up.
Oct 21, 2007 | Oreck XL Ultra Bagged Upright Vacuum
Dewalt DPD3100 Gas Pressure Washer Logo
94 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
