Question about Brother HL 1270N Laser Printer
Brother 1270N faded print
When printing a page approx 1/2 inch on the right hand side is missing or feint.
Have changed the drum and the same problem occurs.
Any ideas?
  • notts1980 Sep 30, 2009
    Turns out that there was a build up of dirt on the laser window that just needed cleaning.
    Remove toner & drum, about 1/2 way in there is a recess with a piece of glass - wipe it clean.
    Prints fine now.
    President:
  • 1,314 Answers
The fuser needs to be replaced.
Posted on Sep 28, 2009
I have the Brother MFC 8860DN. When printing it is missing out a large margin on the right hand side of each sheet and cutting off the text that would normally be in that section
Hi
Are printing with a MS excel file? If yes, go to page set up and click FIT instead of 100% size. To fit is in 1 page only.
Please ask me if did not help you
Mar 06, 2011 | Brother MFC-8860DN All-In-One Laser...
Right side of the page after it prints is blurred or faded. We have replaced the toner and the drum
When you remove the toner and drum unit out of the machine look inside where it was, look up inside that spot where the drum was and you will see a glass window that is about 3/8 of an inch deep and maybe 8 to 9 inches long, it is likely a film of toner is on that glass blocking the laser light from hitting the drum properly. Just use a dry lint free cloth and wipe that glass down and you should be good to go. Remember look up in the spot where the toner was it can be easy to miss it.
Jan 06, 2010 | Brother IntelliFAX 4100 Laser Fax
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
Right side of printed page is faded
pull out your drum unit and look inside machine above where the drum would be. you should see a black assembly that runs left to right with a "****" glass. may need a flashlight. clean that glass off with a clean rag. sometimes toner "scatter" will get on glass and cause this.
let us know,
razors
Mar 26, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
Brother HL2040 PRINTING DOTS
1- change the drum unit
2- check the fuser unit
Sep 06, 2008 | Brother HL-2040 Laser Printer
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
Print quality bad
To clear white vertical lines from printed documents follow the steps listed below:
NOTE: The use of non-Brother or generic toner may cause white vertical lines.
Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
1. First, power OFF the unit for safety. The ON/OFF switch is located on the left, rear side of the unit.
2. Open the scanner cover by pulling the blue lever located below the control panel toward you and lifting the cover. Make sure the cover is completely open.
3. Remove the drum unit by holding each side of the drum by its handles and gently lifting the drum forward (toward) you.
4. Place the drum unit on a drop cloth or large piece of disposablepaper to avoid spilling and scattering the toner. Make sure thedirections and DR-250 stickers are facing you.
5. With the drum removed from the Brother machine, clean the laser glass. The laser glass is located inside the Brother machine where the drum was located. It is a piece of glass, about 1/2 inch wide and approximately 8 inches long, located on the bottom of the inside. Gently wipe the glass with a clean soft DRY cloth. DO NOT use isopropyl alcoholor any liquid to clean the glass.
6. Gently pull up on the mauve lever to turn the toner cartridge toward you until it stops. Remove the toner cartridge from the drum unit by gently sliding it out of the drum unit. ***Handle the toner cartridge carefully. If toner scatters on your hands or clothes, immediately wipe it off or wash it with cold water.
7. Gently rock the toner cartridge from side to side five or six times to distribute the toner evenly inside the cartridge. Then, reset the toner into the drum (be sure it clicks into place). Gently push on the mauve lever to turn the toner cartridge away from you until it stops.
8. With the DR-250 sticker facing you turn the drum upside down. There is a blue tab located on the right side. Slide the blue tab back and forth seven times to clean the corona wire. When finished, make sure the blue tab is locked to the right side of the drum.
9. Reset drum unit in Brother machine. Close the cover securely.
Print the help list to test the unit by pressing the REPORTS key located on the control panel and then (1) on the dial pad.
If the white vertical lines still continue, the drum unit will need to
be replaced.
If the purchase date of the original drum or replacement drum is less than 90 days (within the warranty of the drum), contact Brother Customer Service Center at 1-877-Brother (1-877-276-8437) . The center is open Monday-Friday, 9:00am to 7:00 pm EST, excluding holidays.
Dec 26, 2007 | Brother MFC 6800 All-In-One Laser Printer
Brother HL 1270N Laser Printer Logo
127 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
