Question about Heavy Machinery
I have a LS27TB that has on power to spit a log it just stops ?
  • Chuck
    Chuck May 11, 2010
    Are you trying to split a log with a TroyBilt Chipper/shredder?
  • 389 Answers
You can download an owners manual with parts list and trouble shooting guide here:
manuals.mtdproducts.com/mtd/DocGetter?doc=769-00088f.pdf
Posted on Oct 01, 2009
Humidifier spits out water rather than steam.
Descale the boiler. You do that by putting vinegar in as you would water, start the machine until is starts spitting water then turn off for 30 or so minutes. Turn it back on and let it run. If it stops spitting, dump out the vinegar and flush the boiler with water until you no longer smell vinegar.
Nov 28, 2016 | Humidifiers
What makes the bike spit and sputter then get full power for a bit then go back to spit and sputtering
check your shutoff valve on the tank you might have a small piece of junk blocking it inside your tank...easy way to tell is when you have loss of power stop and shake bike side to side
Sep 08, 2012 | 2006 Harley Davidson XL 883R Sportster
3.8 litre park ave seems to crank right up but spits and shuts off immediately.If I continuallypumpthe gas,it seems to 'catch up and rev up vety high.When I stop pumping,it spits and shuts off.
Is the check engine light on while the engine is running ?
If it is I would start there for clues.
If not, the list of possibilities is long.
You should check the fuel pressure and probably the throttle position sensor resistance. It could have a vac leak too.
Jul 23, 2012 | 1993 Buick Park Avenue
Been putting clear power steering in my 2007 Ford Escort 2.0 and it keeps spitting fluid out of reservoir. And my power steering is out. What do I do?
Sounds like rack is clogged or one of hose is clogged or pinched. Next time you put fluid in it try bleeding it. It's easy, top up fluid then turn wheels all the way to stops on right then back to left stops. Do it a couple of times, but be careful - do NOT hold at stops for more than 5 secs.
Jan 02, 2011 | 2006 Ford Focus
Have a 455 rancher saw that is spitting chain oil out, is there a way to regulate how much oil is automatically dispersed to chain?
If it is spitting oil out, then your chainsaw is working properly. When it stops spitting oil out, then you have a problem. However, on the bottom of that particular saw you will find a little hole with a picture of an oil can next to it. You can adjust the lubricant output via the screw located at the bottom of that hole but, keep one thing in mind; the harder the wood or working conditions your saw is being exposed to the more oil will be necesary to keep your saw running smoothly and your chain from prematurely dulling.
Aug 09, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
My petrol generator is spitting flames.
I would check the floats in the carb. Be careful when pulling the bowl and float, you dont want to loose the pin and needle. If the float has gas in it, it wont be able to work properly so you will have to replace.
Jul 26, 2009 | Electrical Supplies
Car spits and sputters
Major vacuum leak? Do vacuum test. Clean
injectors and check fuel filter. Check timing
too.
Aug 23, 2008 | 2002 Pontiac Firebird
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Heavy Machinery Logo
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
