Question about Jet Plumbing
Sears 1hp shallow well pump pressure switch stops at 50psi
Sears 1hp shallow well pump pressure switch starts at 40psi and stops at 50psi. replaced gage, pressure switch after pressure switch hose popped off the pressure regulator. Replaced hose to regulator and restarted pump. Pumps water and no leaks.
  • tberan1 May 11, 2010
    Please clarify what issue is happening with the pump. Thanks, Tom
    Problem Solver:
  • 10 Answers
What's the problem??
Posted on Oct 24, 2009
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Very low water pressure and excessive pump running
Clean electric switchcontacts with crocus cloth. Adjust higher cut in pressure on this switch.
Apr 12, 2014 | Wayne WATER SYSTEMS SWS50-12P 1/2 HP...
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
My jet pump has a 20 - 40 pressure switch but won't give any more than 30 psi. Whats wrong?
There are several causes for this to occur.
1. If it is a 20-40 switch right out of the box it may not be set correctly. I have had this happen. If it builds to 30psi and shuts right off without straining to build to 40psi adjust the Cut-Out pressure up to 40psi. There are two different adjustments on a well switch. One for Cut In / Cut Out psi and one for Cut Out psi.
2. Lack of head pressure being built by the pump can be the cause. This can be attributed to the wrong Jetting in the pump. IE: A shallow well jet/venturi on a deep well.
3. The pump may have a bad impeller, but the pump will generally really strain to build pressure and a bad impeller will be loud, like grinding at times.
4. Double check the pre-set pressure in bladder tank also.
RJ
May 28, 2011 | Fairbanks Ace 1 Horsepower Convertible...
What preasure should it stop pumping
It is factory preset to stop at 50psi but is adjustable. Do you have a pressure tank in line and close to the pressure switch to assist in pressure stabilization?
Nov 08, 2010 | Flotec TC2151 P2 Well Pump Pressure Switch
Pump will not shut off gives great pressure when running how do i fix this?
This pump runs off of a pressure switch either 30/50PSI or 40/60PSI. It would appear the switch has failed and will need to be replaced. Any Square-D pressure switch will do, head to a home improvement stire and they should have the right item for you. It will cost you @ $10-$15.
Please let me know if this had assisted you,
Tom
Apr 21, 2010 | Flotec Corrosion Resistant Shallow Well...
Need head pressure on 1hp shallow well pump SDTS10
reducing the pipe size helps build head pressure.
Mar 18, 2010 | Plumbing
Low fuel pressure
Remove air filter and unplug the mass air flow sensor and try again. if i cranks clean the MAF. check sensors for skewed readings that won't set codes but will upset computer.
May 04, 2009 | 1996 Chevrolet K1500
Plumbing Logo
487 people viewed this question
Top Jet Plumbing Experts
Lawrence Oravetz
bobalix
Are you a Jet Plumbing Expert? Answer questions, earn points and help others
