Problem with Toshiba Equium Laptop which is switching itself off. even when connected to mains supply Is this a problem with the switch or power supply? Hope you can help thanks
If the laptop shuts down and won't boot up straight away, then the problem could be an overheating CPU problem. It could be a faulty fan and/or the fan and heatsink assembly is clogged with dust.
Check the fan and if it has stopped spinning then replace it and if the fan and heatsink is clogged with dust, loosen the dust and remove it.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
Thanks for info and have cleaned unit which did not appear to be blocked
Fingers crossed and many thanks
Mike
" - mike480
How hot is the unit getting? I had a similar problem with my laptop and all I did was clean the airflow vents for the processor and its working fine now,
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Many thanks
Cleaned but did not appear to be blocked
Fingers crossed
Again thanks
Mike
" - mike480
Windows does not see the Nvidia G100 video card in the PCI-E slot. Does not even show up in device...
(More)
Windows does not see the Nvidia G100 video card in the PCI-E slot. Does not even show up in device manager. Tried to install drivers, but the driver installer says that I don't have any compatible hardware (aka, it doesn't see the card either). Everything is factory new, all drivers are p to date. Tried disabling the onboard video and setting the BIOS to default to PCI-E. No go.
My older Dell dimention 2300 created photo and audio Cd's do not play in my dell optiplex gx270 cd...
(More)
My older Dell dimention 2300 created photo and audio Cd's do not play in my dell optiplex gx270 cd rw/dvd player. Any advice?
