Its not draining properly..plus fashing lights come up
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Check/ clean pump / filter
Posted on Sep 28, 2009
Why does my kennmore smartwash elite keeps beeping and fashing f 02 signal
Your drain pump can't drain all the water, so your drain pump has a cap on it to clean out the filter. Clean the filter and try again, if this code comes back, replace the pump. Good Luck
Aug 17, 2014 | Washing Machines
My buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops green...
My ministation was doing the same, beeping and flashing green light after a light drop on the floor. Soo... I took my ministation usb drive out of the plastic enclosure and smacked it on the table a few times. Plugged it in and it spun back up!! Now my computer recognizes it and everythings working smooth! I assume something with the drive became jammed and the couple smacks loosened the drive head.. Anyway, if all else fails... beat it!
Nov 05, 2012 | Buffalo Technology Buffalo MiniStation...
Samsung frontload washer fashing nd code
The ND code means not draining
The older versions of this machine did not have a debre filter, but in later versions a drebe filter was added . It is on the bottom right of the front panel. Open the door. Pull the cap off the drain hose and drain water into pan. Remove filter cap. Wash filter off and don't block propeller when replacing filter cap. Insert cap back in drain tube.
Jun 04, 2011 | Samsung WF328AAW Front Load Washer
F11 fashes drum wont turn water styill in machine
this a big and a little bit messy job to do. you can first drain the water through its drain plug usually it is located lower front panel of the machine.
after completely drained, unplug the unit to avoid electric shock and open the lower panel of your machine. this is a little bit tricky to find the screws, patience is required and also screw drivers and other tools. after opening, locate a float switch under it if its working properly and other switches inside. also the important part is to check on its drain valve probably something clogged into it that is why it is not working properly. you need to open the tube pipes to access it.
please refer to your manual on the parts of your machine...
hope i give you an idea...
Jan 01, 2011 | Kenmore HE2 Plus Front Load Washer
Standby light fashes and when I swich it on it come for a second then turns of and standby light fashes again?
no especifica si es de baterias o de adaptador ac dc revice si es de bateria y cambielas y si es de adaptador revisar que tenga coriente con un voltimetro
Oct 05, 2010 | Audio Players & Recorders
WHAT DOES THE THREE RED FASHING ;LIGHTS MEAN?
your system needs an x-clamp replacement. cause cpu or gpu has to be reflowed. this is your cause. i have been fixing this problem for over 2 years
Jun 07, 2010 | Microsoft Xbox 360 Console
IDL40 Not draining water off and 2 green lights fashing - what do we do?
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump, like the occasional stray piece of clothing, and check the pump impeller. Make sure there are no broken or missing blades and that the impeller will spin freely. If any blades are broken/missing or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 28, 2009 | Washing Machines
Air bag light fashes 46 code. I know it is the
This is worth checking
Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag fault
Sep 05, 2009 | 2003 Ford Escape
13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
