i have similar problem. its keep blinking with "DE" indication. Thank you jerryoah. you save my day and money. thank you so much. Luckily my wife didn't throw away the tiny magnet. thank you again.
The "DE" code indicates a door open error. This can be caused by the door not closing all the way (this could be because of bent door/hinges or the door gasket bunching up and not permitting the door to close properly), loose electrical connections at the door switch or powerboard assembly, or the door switch itself is faulty. It can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity would mean a bad switch. Also check the door gasket for "bunching" and you can unplug and reseat electrical connections. These are some areas to look at. Be sure to disconnect unit from power before attempting any repair/troubleshooting. Really sorry for your trouble and I hope this helped. Best wishes.
Comments:
Sep 28, 2009
- I apologize sir. I should have read your post more carefully. I see that a fellow expert has already assisted you and I am glad that your wife didn't throw away that door magnet and that you resolved your problem. Great! Have a great day and thanks for using Fixya.
Was this helpful?
Yes
No
Popular Solutions for LG WFT1071TP Top Load Washer
Top Loader fuzzy logic 5.0kg LG washing machine (model wf-t502A) isn't draining. Not sure where to...
(More)
Top Loader fuzzy logic 5.0kg LG washing machine (model wf-t502A) isn't draining. Not sure where to begin.
my lg washing machine wf-s6607tc soon after start washing it stops then spin and drain lights comes....
(More)
MY LG WASHING MACHINE WF-S6607TC SOON AFTER START WASHING IT STOPS THEN SPIN AND DRAIN LIGHTS COMES. AFTER READING THIS SITE I GOT TO KNOW THAT THERES A MAGNET ON THE TOP FRONT COVER. SO I BEGAN SEARCHING FOR THE MAGNET. BUT ITS GONE.. SO WAT ELSE CAN I DO?
