Question about Evolis Tattoo Thermal Card Printer
Print riboon installed but light keeps coming up as "end of riboon" and cards are not being picked up
My fargo hdp600 keeps printing a white edge in the front of the card
please go to the print preferences and card there you will the card adjustment card size print width print length and card type are all there you can make your ajusment there and also patriot or lanscap
Mar 22, 2014 | Fargo Office Equipment & Supplies
The oil light in my 1985 Mazda 626 keeps coming on although there is plenty of oil in the engine. I checked and topped the oil up less than a week ago (before a road trip) and today the oil light came on....
The oil light will come on with low oil pressure (it is most likely a faulty / blocked sensor). This could be a simple sensor fault or blocked pick-up or a problem with your pump. I would get it checked out - if the oil pick-up needs to be replaced or cleaned the sump would need to be removed. A quick visual is to open where you top up the oil and see if you can see no oil at the top of your engine if there is very little or none then it is definitely the pick-up and don't drive the car as you will cause wear. If you start your engine you should see oil "sloshing" in the top end - again if there is none then there is no lubrication for the top end.
Feb 01, 2013 | Mazda 626 Cars & Trucks
Printer won't pick up the paper in the tray to print. Keep getting out of paper message
First check if the feed rollers are 'Slick" with paper dust, if they are ,clean then with 409 on a cloth rag, and scrub till u dont see the white paper dust on the rollers, let the rollers dry, then reset the printer, by turning it off. then turn it back on ,reinstall the paper and begin printing again.
Jul 15, 2009 | Office Equipment & Supplies
I have a blank line across all the cards
If the line is across the card from end to end on the long side in the same spot every time, then try cleaning the printhead. If it is still there then you most likely need a new printhead.
Jun 26, 2009 | Zebra P330i Thermal Card Printer
Printer cannot print.
HP Deskjet 1125c printer - Printer does not print. Bottom orange light keeps brinking. Paper cannot not even be picked up by the printer.
Jan 17, 2009 | HP DeskJet 1125c InkJet Printer
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
Dec 10, 2008 | HP Deskjet 2330 InkJet Photo Printer
X6 won't pick up DSL
hopefully you haev installed the software first on yoy computer>
turn off the computer. connect the phone line one end to the ethernet port on your computer and the other end to one of the LAN port on the x6.
power up the (power cube shipped with the X6), the Pwr and the WLAN should come on and become steady, the LINK light should blink,
turn on you computer, connect a new phone line between ADSL port and the wall jack, the LINK light should become steady.
please rate the answer if it solved your porblem.
thank you
Sep 09, 2008 | Zoom X6 (5590) DSL Modem (55900003)
HP670C DESKJET PRINTER
Dear Sir.
Kindly see that you have used Genuine Cartridges.
RegardsRafique
Mar 28, 2008 | HP DeskJet 670c InkJet Printer
The game stopped
Hello matbedui,
If you think the Radeon card is overheating you can check this by simply touching the card after it's been running for sometime. Some Radeon cards (high end) do have this problem. PC cases that do not have sufficient fresh air flow cause problems not just to video cards but to everything inside the case. The design of the HIS Radeon X1650 is less than sufficient. Keeping air flow contained. One way in & one way out. This issue is so important many companies creat sites to help you cool your card.
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=196
Your Radeon X1650 Pro IceQ II runs ATI's chips. Installing the latest software is recomended. Download from here:
http://ati.amd.com/support/driver.html
Pick your OS. Than pick Radeon. Scroll down to your X1600 series. You can also update through HIS. Their software is twice the size of the ATI software.
http://www.hisdigital.com/html/driver.php?id=64
Feb 24, 2008 | HIS RADEON X1650 Pro IceQ II, (256 MB)...
Evolis Tattoo Thermal Card Printer Logo
37 people viewed this question
Top Evolis Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
Fred Block
Fred Block
k24674
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
