Question about HP LaserJet CP4005n Printer
Control Display is off, although pritner is plugged in 220v, and the fan is working (printer IS switched on).
  • 52 Answers
Uninstall the printer and reinstall it properly. you can also check for a driver in the internet.
Posted on Sep 28, 2009
Invalid header
You are seeing the "Invalid Header" message on the LCD display on the T2250 because the pritner is in "boot" mode, which is the firmware download mode and is detecting data being recived is not a correct firmware file.
The most likely cause for this problem is the pritner has defaulted to 'Firmware Download Mode" due to a problem with either corruption to the firmware or damaged / faulty EEPROMS. When print jobs are sent to the pritner the pritner is expecting firmware and recognises the data it is reciving is not correct for a firmware file.
The solutions to this problem are;
  1. Power the printer OFF, disconnect the printer from the computer system, and any external print server (eg JetDirect etc). Power the printer back on, if the error is resolved check the method of connecting the printer to the computer system to ensure there is no damage to cables etc.
    If the printer displays "BOOT" on the display this indicates the printer is in firmware download mode.
  2. If the display reads BOOT first try reloading the firmware you may find details and firmware on the following web site,
    http://support.dascomeurope.com/index.php?option=com_docman&task=cat_view&gid=123&Itemid=48&lang=en
  3. If loading the firmware fails this indicates a logic board fault, the main logic board would need to be replaced to resolve the issue
Feb 18, 2011 | Tally T2250 Matrix Printer
No display on power up got as gift it is 110v but
Did the 220v converter got too hot? Try another larger 220v converter?
Nov 15, 2010 | Vizio VA26L 26 in. LCD HDTV
My HP 8500 stopped printing my Quickbooks 2009 checks. It worked fine for about 5 months and then stopped. I installed updates for both Windows and QB 2009 and reinstalled the HP drivers for my printer but...
click on start go to control panel. go to pritners. click on add a printer option on top of window. then add a local pritner. add deskjet 990c drivers use existing ports
Dec 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
The printer prints part of a page from some sites, some site the whole doc and some site a enpty page
solution 1>
click on start go to control panel go to pritners adn faxes or pritners in vista or win 7. then click on add a pritner. add a local pritner then hit next. choose existing port usb vertual pritner port. then hit next. under manufacturer select hp and under prtiners select deskjet 990c. hit next. do not share this pritner. finish add printer wizard. try pritning
solution 2>
click on start then click on run in open box type
%temp% hit enter. in vista enter %temp% in start search and hit enter it will open temp folder with lot of foledr optio0n find low folder adn delete it permanently then restart computer
Dec 16, 2009 | HP DeskJet 5550 InkJet Printer
Eject Error message
I would suspect that the paper path has been changed via the control panel. If you are using continuous paper fed in from the tractor this should be Tractor 1 (unless you have optional tractors).
If the printer shows something like SINGLE on the display, it is for sure that the paper path has been changed.
Disconect the pritner from the computer system, and power the pritner off and ofter 10-15 seconds power the printerback on again.
  • Take the printer off-line by pressing the Online key
  • Press the Setup key
  • Press the key under "Paperway" in the display
  • Select Tractor 1 (or Tractor 2 if fitted/required)
  • Press the key under "Set"
  • If the menu shows as locked power the pritner on holding down SETUP to unlock the menu.
    Nov 18, 2009 | TallyGenicom T2265 Matrix Printer
    J6480 fatal error 2753 MSI.dot4wrp during full driver install. I tried uninstalling al related hp drivers, all the HP advice. Disabled firewall, services etc. Do you have a solution that works?
    you can try with installing the windows installer 4.5 and then try.. otherwise reinstalling windows might work because the error you are getting is related to installer.. and its a service of windows itself which is responsible for all the software installation..
    Oct 29, 2009 | HP DeskJet 648c InkJet Printer
    We are setting up new TallyGenicom LA800. However, printout has dot or period in between each characters printed. Hence, a single row info is printed on two rows. What seems to be the problem?
    It would be strange for the printer to print dot between each printed character without this coming from the system.
    As a check the first thing I would recomend doing would be to print a self test print on the printer, you can do this easiest by printing a menu print.
    To print a menu print put the pritner OFFLINE
    Press SETUP
    Press the button under MENU
    Press the button under PRINT.
    The printer should print out its configuration page, if this has dots between each character then this defiantly means you have printer problems.
    You can try defaulting the pritner back to factory settings, this is down by holding down the four buttons (1, 2, 3 & 4) under the LCD display whilst powerind the printer on.
    If the menu prints OK, then there is some sort of other strange system or communication problem.
    If the pritner is connected via serial, check the serial settings on the pritner also chack the pin configuration of the connector used to print to the printer.
    Try printing from another system or application to identify what might be causing the problem for example an application or driver problem, perhaps try printing from a PC directly to the pritner to check the interface on the printer is OK.
    Check the emulation setting on the pritner ensure this is correct.
    Aug 02, 2009 | Epson Stylus Photo 2100 InkJet Printer
    Error Code: 2753 " Fatal Error or error MSI.dot4msi"
    CAUSE:
    Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
    The Windows services (files) were:
    Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
    Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
    The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
    SOLUTION:
    Steps:
    1) Check to make sure that the 2 Windows services above are not running (or not installed).
    2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
    3) Run the installation again.
    solution 2>
    complete uninstall printer software from computer.
    run uninstall L1 L2 L3 L4(if not an hp computer).
    run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
    then clean from add remove programs/program and features.
    then clean from cleanup utility all hp pritner related entries.
    then clean temp folder. clean recycle bin.
    delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
    delete following folders from following locations-
    C:\windows\System32\Spool\Printers and deleted entries inside it
    C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
    C:\windows\twain_32.
    cleanup from regsitry--
    plz make back up for registry first.
    >> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
    >> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
    >> hklm/system/current control set/enum/usbprint delete pritner entries.
    >> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
    >> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
    >> delete same ports from printers and faxes/pritners pritner properties ports
    >> hklm/system/current control set/control/print/monitors/hpz..
    >> hklm/system/current control set/control/print/providers/lan man settings.
    >> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
    >> hkey_Current_User\Software\Hewlett-Packard
    >> hKey_Local_Machine\Software\Hewlett-Packard
    >> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
    >> hkey_current_user\software\hewlett packard delete if not hp computer.
    >> hkey_curent_configuration/system/current control set/control/print/pritners.
    then go to msconfig
    make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
    after restart install cue version 12 officejet pro 8500 or 6500.
    then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
    then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
    issue resolved.
    Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
    Format Board Problems
    Ok try this..uninstall all drivers for this printer..unplug..reboot...download new updated drivers for hp website....reboot..after reboot..plug in printer..make sure you use a known good usb cable....system should see printer and install new drivers...if not go into control panel and add new printer...if asked for driver location point to where you placed drivers from download.if still confused or need more help contact me or one of our other experts or our online chat.We are always available to assist you with a problem.RICHARDM69
    Dec 04, 2008 | HP LaserJet P2015dn Printer
    HP LaserJet CP4005n Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
