Question about Servis Dishwashers
Just looking for some advice on removing the drawer from my servis washing machine, sorry I dont know what model it is. I need to clean the powder drawer but cant find any way to remove it from the machine. There is no internal part marked push that i can see and im wondering if i need to unscrew the four screws around the drawer. Help please! Cheers
    President:
  • 1,185 Answers
Send an email to this address asking for the user guide for your model
repairs@servisuk.co.uk
Posted on Sep 28, 2009
There is caked washing powder let over in the tray after every wash and the clothes are not being washed properly. How do I fix this?
read the user manual for the right section to use
if you do not have a user manual then go google and type in ---user manual for ( make and model of machine ) and download a pdf version
personally washing detergent powder causes more problems that what it is worth
change over to liquid detergents
Oct 28, 2015 | Washing Machines
Servis wp1249f2w leaving powder in the drawer each time, any solutions?
Stop using powder. Use liquid instead and see if that makes a difference.
First off. Before changing the detergent clean the residue of the powder from the tray.
Another thing to keep in mind is the type of detergent.
You want HE detergent. The reason for HE is it uses less and leaves nothing behind. ( HE stands for High Efficiency detergent.)
Hope this helped.
Mar 09, 2015 | Washing Machines
How do you use the tub clean?
Read these instructions carefully before
beginning the TUB CLEAN cycle.
Open the door and remove any clothing in
the wash drum.
Open the dispenser drawer.
Add liquid chlorine bleach or tub cleaner.
Some powder or tablet tub cleaners which
are manufactured for this purpose can be
used.
(NOTE : Do not add any laundry detergent
or fabric softener to the drawer when using
TUB CLEAN.)
- If using liquid chlorine bleach
Add liquid chlorine bleach to the bleach
compartment of the drawer.
(NOTE : Do not exceed the maximum
fill line and do not pour undiluted liquid
bleach directly into the wash drum.)
- If using powder cleaner
Remove the liquid detergent cup and
add powder cleaner to the main wash
- If using tablet cleaner
Add tablet cleaner to the wash drum
directly.
(NOTE : Do not add tablet cleaner to the
drawer.)
Close the drawer and washer door.
5
Select TUB CLEAN and press START.
NOTE : It is recommended that TUB CLEAN
should be repeated monthly.
If mildew or musty smell already exists, run TUB
CLEAN for 3 consecutive weeks.
After TUB CLEAN is complete or when the washer
is not used, leave the washer door open for better
ventilation and drying inside of the washer
Jul 05, 2014 | LG WM2701HV Washer
How to clean the wash powder and conditioner compartment on Servis Easilogic 1300rpm?
There will be a release catch somewere, but if you cant find it, boil a kettle and pour it in to the compartment, then follow with more warm water till it is clean.
Sep 25, 2012 | Washing Machines
I have ge washing machine, i dont know how to clean specilally, the part that i put the powder and fabric, shall i moved out?
The conditioner/softener tray needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Mar 10, 2011 | GE Washing Machines
Hi there I have a Hotpoint WF541 washing machine. It has worked fine for 2 years, but now leaks a small amount of water from the soap dispenser down the front of the machine onto the floor. If...
Hi Sheena from retired Englishman in SW France @ 21:51 Sun evening (nothing on TV!)
Sorry if this seems a silly question/answer but have you removed the dispenser completely and ensured that it is not blocked anywhere, especially the conditioner/softener drawer area? Normally the pre-wash and wash powders sit in open ended trays to drop straight into the drum but the conditioner does not. It is not allowed out until the right time- it has to be flushed/siphoned out by the water feed. A common problem is that the tube/pipe which is in this tray down which it siphons is blocked- possible by a mix of powder and conditioner. It is easy to accidentally let the powder spill into it when filling.
My advice is to pull the drawer completely out and give it a good clean out, especially the conditioner bit!
Dispensers are removed either by pulling almost all of the way out then 1) pressing down on the lip at the rear to clear or 2) releasing the clip underneath the dispenser or 3) by lifting upwards just as you are pulling it out, whichever is the way for your machine.
Hope this cures the leaking!
Best of luck,
John C
Feb 06, 2011 | Washing Machines
Water coming back into Soap Powder BOx Filter Blocked Need cleaning out?
remove soap drawer this is easy it just pulls out clean this then look into the hole incase there is a lump of powder blocking the inlet pipe and clean
Jun 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
Water leak from front powder/conditioner drawer.
Completely remove the dispenser unit. look inside the recess you have just taken the dispenser drawer from and look up. You will find this is covered in muck. Clean it with an old toothbrush or something but do not use too mush pressure. This should solve your problem. If not then you will need to replace the dispenser unit completely
May 22, 2010 | Whirlpool AWM5125/1 Front Load Washer
Washing powder clogs up in drawer
There should be an adjustable "barrier" in the drawer. One for liquid and one for powder. Open the drawer and look at it carefully, you may need a flashlight. See where you pour the powder in? Well... you know what they say about pictures and a thousand words...
Since I don't have your model number, yours will probably look different than this pic,, but it should be close enough. All you have to do is set the barrier to the "Powder" setting.
SG
Mar 26, 2009 | Washing Machines
Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Oct 07, 2007 | Washing Machines
Dishwashers Logo
237 people viewed this question
Top Servis Dishwashers Experts
Owen Barnes
Are you a Servis Dishwasher Expert? Answer questions, earn points and help others
