Question about Garden
Need to see how the springs fit having a problem with how the linkage works on a briggs and strattton 4, its a small walk behind mower about 10 years old
Can't find year or parts for this engine any help is good.
mod 14 type 202052 ss 156403 its a briggs and stratton.
Posted on Dec 02, 2011
  • william zadroga Dec 03, 2011
    Scholar:
  • 135 Answers
That motor has a little linkage on it. One end has a loop in it. Purchase a new governor spring that matches the model of engine you have. The spring should have a closed loop on both ends that'll come open if you look close enough. One end hooks onto the link with the loop in it, the other end hooks to the section that the cable connects too. Very simple but yet if not installed properly can cause you a nightmare when it comes to rpm's and governor working properly.
Posted on Oct 09, 2009
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
How do I refit linkages and springs and in what order on unidentified lawn mower?
Linkage & Spring replacement on a Briggs & Stratton ...
? 7:13
https://www.youtube.com/watch?v=8atnwA4D5lM
Jun 26, 2010 - Uploaded by paisteboy
In this video I replace the two spings at the linkage on the carburetor of my Murray Lawn Mower that has a ...
4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close ...
Nov 24, 2015 | Garden
I have a 6.5 B&S engine on a RYOBI lawn mower That will not come up to mowing RPM. the mower does not have a throttle cable and the spring on the throttle appear to be intach. The engine starts real...
Normally when you move the throttle control on the handle, all that is happening is that governor spring tension is increasing or decreasing pull on the linkage /governor arm. With engine off and plug wire removed, look for a small shaft coming out of the engine with an arm attached. Attached to the small arm will be linkage to the throttle on carb.. So when you move the throttle on the carb with your finger the arm moves also. There should be spring connected to opposite side of governor arm connected to throttle control at the handle or small lever or metal tab. When you incease pull on the spring, the engine will speed-up. Adjust as needed. Good luck
Jun 28, 2011 | Briggs Stratton H7159 & Stratton® 5500,...
What is the proper weight oil for most walk behind mowers.
SAE 30. If you run synthetic (hard to find in SAE 30W) then you can get away with using a muti-viscosity oil like 10-30W. Briggs and Stratton are very adamant that ONLY SAE30W be used in their small engines.
May 07, 2011 | Yard Man YardMan 173 cc OHV 19" 3in1 Rear...
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
Push mower with 4 hp Briggs motot surges, small
If the spring has only become dislodged, and not broken, you just need to find out where it goes. Take a digital picture of the carburetor from the top (you may have to remove the plastic shroud). Take another from the side, and from wherever else you can get an angle. Take the camera and small mirror with you to a place that sells mowers. B&S doesn't change their engines & carbs very often. You just need to find any mower with a 4 hp B&S, or even a 4.5 to 6.5 will probably be similar enough.
Jun 23, 2010 | Mtd 22" Yard Machine Push Mower
I have an old Briggs and Stratton engine 16hpv. I
I am trying to find you a spring..i have a bunch of old stuff out back. give me a couple days. It holds the diaphram steady to prevent chattering of the rubber while fuel is flowing...:)also what year is your briggs and model?
Sep 07, 2009 | Garden
Briggs and Stratton Governor Linkage problem
The easiest thing for you to do is look at any 12.5-19hp Briggs single cylinder engine that's on just about any riding mower.. They all have the same set-up.
Jun 10, 2009 | Garden
Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
May 19, 2009 | Garden
Garden Logo
329 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
