Question about Husqvarna Garden
262 XP engine cut out on tickover, now will not start
Very reliable saw, well used but well maintained. Have been using daily for a week before problem started; put saw down on tick over to stack timber, saw cut out and would not start. Left for half an hour and saw started, run for half a tank of fuel then stoped, now cannot start. Seems to be fuel getting to the spark plug, replaced with new spark plug but still no start. Help!
  • Cyril Ross
    Cyril Ross Jan 07, 2012
    I have just put together a 262, when i started it, iidles fine, but it has no top end?? The 262 that won't start, it might be gas tank vent.....
    President:
  • 2,220 Answers
Try checking for spark when she won't start. I'll wager your ignition module quits when it gets good and warm. HTH
Lou
Posted on Sep 28, 2009
Failed to start twice in 3 weeks time I drive it daily I used starting fluid both times to get it to start what could be the problem?
Is your check engine light on n can you drive it to autozone get free diag I need to know what codes r store in your PCM sounds to me like crank sensor it fires your injector n coils but to be on the safe side give me the codes ok good like
Oct 02, 2015 | 2011 Hyundai Sonata 2.4
Savoirfaire oven
I have used Repair Clinic.com in the past and have found it to be helpful in fixing wall oven.
Jul 14, 2014 | AEG Ovens
Use maintain chainsaw
if your question is "best way to care and use a chainsaw"
care: well that's slightly different for a gas model vs an electric model
gas models should not be stored for longer than a week with fuel in it's system (tank,lines,carb) as the gas will evaporate and cause deposits to form (hard) and clogg up the small ports in there
electric models, should be inspected for cuts to cord and general safety ck over saw to make sure it's not going to shock you
just because they show it on tv , chain saws are not for cutting in water or around water , one its not good for the metals the saw is made from and two if water gets inside the motor (gas or electric) its no longer going to run anymore
always keep your chain oiler full of bar oil (not motor oil) and top off every 30 min of use
and sharp chains cut cooler and longer than dull chains , lot less effort too
Jan 08, 2014 | Black & Decker Garden
How critical is the oil/petrol mix ratio in terms of starting and maintaining engine running for a McCulloch 2 stroke chain saw?
All the lubrication for the engine comes from the oil mixed with the fuel, so it is VERY important that you use good quaility two stroke oil designed to be used in a chainsaw, and mixed as per the manufacturers recommendations, if you are not too sure then run a 25.1 fuel oil mix, if the egine lacks lubrication the piston will start to scuff around the exhaust port ( the hottest part of the engine ) lose compression and become difficult or impossible to start. A quick check is to remove the muffler and take a look at the piston skirt through the open exhaust port.
Mar 06, 2012 | McCulloch Garden
What gas to use for TS350
Gasoline cut-off saws are a simple and extremely robust tool that will easily last for many years if treated with respect and maintained regularly .
During normal operation it is absolutely imperative that the correct fuel/oil mix is always used. An incorrect mixture leading to a lack of lubrication is by far the easiest way to ensure an untimely death for your cut-off saw.
Here's a list of regular cut-off saw maintenance tips that will keep your machine running and running:
Jul 20, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
How do you remove the sprocket and clutch assembly
Article: Fixing a Broken Chainsaw
Having a broken chainsaw is an inconvenience. Having one that works when you need it is important! Chainsaws are useful tools for tree pruning, cutting firewood, and carpentry projects, but are not so useful if not properly maintained. It can also cost a great deal of money to get a broken chainsaw repaired. You can save a lot of time and money by repairing it yourself. For chainsaw repair you will need a blanket or large cloth, a chainsaw tightening tool, files to sharpen the blades, and any necessary replacement parts.
My Chainsaw's Engine Does Not Start
If the engine will start at all, you might have a bad starter switch. Check to see that all connections to the starter switch are secure. Is the power cord cut or broken? Check to make sure that you have a proper power line connection. If all checks out except for the switch, go ahead and replace it. You may want to consider whether you are using the appropriate fuel mixture.
My Chainsaw Smokes
If there is smoke coming from the chain, it could be an indication that there is not enough lubrication. Without the proper lubrication, the chain and chain bar can become seriously damaged. Make sure there is oil in the reservoir. When you start the saw, the automatic oil pump should lubricate the chain and bar. To see if this is a problem, hold the saw tip over a light-colored surface, hit the throttle and look for oil spatters on the chain bar. If you see no oil splatters, turn the saw off. Remove the chain guide bar and see if the oil discharge slots are clogged with sawdust. Clean out the sawdust and restart the saw to check lubrication again.
The Chain Skips or Jumps
If the chain skips or jumps during operation, check the engine drive sprocket to make sure it is not worn. If you have a worn sprocket it will not allow the chain to sit properly. Also, check to make sure the chain tension is set correctly. Setting the chain tension is a part of continuous operation. However, a dull or damaged chain may also cause the skipping and jumping.
My Chainsaw Isn't Cutting Properly
If the saw cuts at the wrong angle or shoots out a lot of sawdust, you probably need to sharpen the chain. A dull chain can be very dangerous. It can cause a kickback or chain jump that might break the chain and release pieces that could harm to the operator. If your chain is very shiny, you need to examine each cutter for damage. Use a file to sharpen the cutters.
The Chain Continues to Move or Stops
If the chain continues to move while the engine idles then you should check to make sure the idle is not set too high. If it stops while cutting, see if the brake is engaged.
My Chainsaw Loses Power
If the saw loses power while operating, check to make sure all electrical connections are secure. Any break in current may cause the saw to decrease in power, stall or shut down altogether.
When maintained, chainsaws are a great asset to any tool collection. Consult your user's manual for questions specific to certain manufacturer types.
About the Author:
Oct 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Recently when returning from a trip my C550 giving keptme the message "satellite unable to locate" (not the exact words) This went on for a week or more but suddenly started locating me from the satellite....
Low battery power is generally r4esponsible for loss of signal or low signal. Charge itr fully before use and plug into car power source ONLY AFTER staring the engine so as to avoid spike deamage. The car charger cannot fully charge the battery it is justn sufficient to maintain a level of charge . If the battery gets too low it cannot maintain a constant signal.
Jul 24, 2009 | Garmin StreetPilot c550 GPS Receiver
I am running a six inch blade width horizontal band saw in a sawmilling application, resawing flitches to thinner boards. Average depth of cut about eight inches. What blade life (swage set steel) should I...
This depends on the type of wood you are cutting. Hardwoods , like oak, will dull the blades faster and require a change after about 3 months if used daily 8x7 but you can get a longer cutting time IF the blades are carbide steel. You can add life to the saw teeth by keeping them clean and free of sap buildup too.
Specially when cutting pine.
Jul 12, 2009 | Saws
Garden Logo
528 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
