Question about AEG Washing Machines
C9 on dial.. was clogges due to blanket
C9 on dial.. was clogges due to blanket disintegrating now crear.. can i reset the C9 and how..
    Genius:
  • AEG Master
  • 1,474 Answers
First you need to clear the blockage , it helps knowing make of machine, as a rule check /clean filter
Posted on Sep 28, 2009
SF-P95JJ GIVE ERROR C9
Not "hitachi washing machine error code c9 what to do"
electronicsfurnitureinfo.com/.../hitachi-washing-machine-error-code-c9-...
Info about hitachi washing machine error code c9 what to do in Electronics ... What do you think about this washer Electrolux ZWT-61M, do you like the design?
Jul 28, 2015 | Washing Machines
How to reset aeg 88840 update ? Have c9 error, don't know reset combination, please help!
Error code C9 means tachometer impulses are missing so you could check carbon brushes (mostly), motor drive, tachogenerator, wiring.
Dado
Feb 22, 2015 | AEG Washing Machines
Jura c9 on out of box start up won't leave rinse cycle and enter heating mode. Checked rotary dial but it seems fine.
You need to be patient and keep pressing the rinse button. I took a few water tanks of rinsing before it clicked over to heating mode. The manual and DVD need to mention this!
May 13, 2011 | Jura Capresso Capresso IMPRESSA C9 One...
The machine flashes C9
On washing machine displaying error code "C9" on its' display. Normally this indicates that there is a mechanical or electrical problem with the motor (often the brushes need to be replaced).
It could also be an over-sized load of clothes in the machine, try to reset the before beginning to replace parts.
The solution is to put the dial in the off position, then turn the dial to the spin position while holding down the soak and pre-wash buttons simultaneously.
The procedure above is also necessary to reset the washing machine after replacing any parts once the error condition has occurred.
Feb 19, 2011 | AEG Lavamat 88840 Front Load Washer
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Thanks
Jun 04, 2010 | Washing Machines
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
I need a motherboard for a aeg lavamat l62622
I have an AEG WITH ERROR CODE C9 IT WONT SPIN OR WASH ,COUNTS DOWN THE CYCLE ,FILLS BUT CLOTHES ARE LEFT A STICKY MESS ,MOTOR AND BUSHES ARE FINE ,I HAVE RESET NUMEROUS TIMES BUT STILL GOES TO C9 ANY IDEAS
Feb 26, 2010 | AEG Washing Machines
AEG Lavamat washing macine C9 error code
C9 is a motor fault.
Normally it's worn out carbon brushes so you'll need to check them first.
If worn out or broken, replace them.
Then, you need to erase the code (reset the machine).
To do this, turn the dial to off.
Press and hold together, prewash and soaking buttons.
While holding them, turn the dial 1 click anti clockwise.
Release the buttons.
Turn the dial to off, to any program and back to off.
This should get rid of the C9 code.
It will come back if you don't repair the motor fault.
Dec 10, 2017 | AEG Lavamat 88840 Front Load Washer
AEG 88730 UPDATE
For a solution to your dilemma, I recommend that you first replace the brushes, then to reset the error code C9 hold down the pre-wash & short wash together and turn the control knob from off to gentle spin. this sequence should clear the C9 from your washer.
Aug 18, 2008 | Washing Machines
Washing Machines Logo
207 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
