Question about Gigabyte GA-8ID533 Motherboard
Computer stopped responding ! Nothing appears.
Hi
I have a GA-8ID533 Motherboard. Nearly one month ago my computer started to reboot again and again. When it came up , after 10 minutes of operation it showed a blue screen showing the progress of dumping RAM or something. Now it does not boot at all. It just turns on and the green light is on , but nothing appears on the monitor. Also there is no drive activity. Just fans work! I think the motherboard is burnt. Any other possibility? Please tell me.
  • 16 more comments
  • Gr8MP Dec 18, 2007
    Thank you man!
    I did that BUT it did not make any difference. You know ? I think it is damaged. I mean the motherboard. Any other suggestion ?
    Hey Tom !
    I should appreciate you for caring. Anyway I should clarify one thing: When the computer starts the system does not perform POST ,as I know, and nothing actually happens except turning on of a lamp and fans. Thats it. Considering this please answer to my question. I do not think RAM can make the system perform the POST or otherwise stop its operation.
    What is your idea ?
  • Gr8MP Dec 19, 2007
    Yeah! Two of them look the same as pictures. So what should I do now ?
    Oh man I changed the two capacitors and the system did its POST. BUT in the middle of the setup of windows it shows that blue screen dumping the RAM .... . So what should I do now ? You mean even now I can not do anymore?! Please help me. I was getting hopeful!
    Thank you man. I will do that. In the mid time can I test other caps ? I am doubtful about them. Can you tell me how can I test a capacitor ?
    I can get into BIOS and did the same as you said and tried everything there. But nothing changed. Just after a few minutes (1 or 2) the blue screen of memory dumping appears and the computer stops responding. As for the update, I have not added anything new to my computer, so why is the need for update. It worked well formerly. Any other suggestion please ?
    Thank you.
    Thanks. But how I can test the RAM? You know I can not install anything on it because that dark blue screen comes in. Also I do not have any other computer able to accept SDRAM!
    Thank you. I have a friend who can provide me a used one. I will test it within the following three days.
  • Gr8MP Dec 22, 2007
    Hi
    I tested another Ram on the motherboard and the results did not change. Nevertheless I could install windows 98. However from time to time it shows windows 98 blue screen instead of the one of windows XP . That when it comes is unpredictable. You don't think another part of the mainboard or the system is damaged. Please help me. Thanks.
    It is different every time and each time shows a different group of numbers.
    Yes, it shows everything.
  • Gr8MP Dec 23, 2007
    I scanned the hardware using a program. It says there are some problems in the disk. Can it be the cause of stop? I want to know that is it so important.
    One thing , the computer never ever stops responding unless I do a hard a semi-hard disk activity or system activity. Please respond to me.
    Thanks.
    Here is one of the errors:
    A fatal exception OE has occured at 0028:c0041AC1 in VXD VFAT (01) + 0000A1F1
    I actually think I have not installed that with Windows 98. Anyway I will change the HDD and inform you.
    I know. I checked the HDD on another system and it worked fine. So it was not the problem. So the things remain are the CPU and the motherboard itself. Can you tell me where is the problem and whether it can be fixed or not?
    Thanks.
    So you think I should replace the motherboard , I mean buy a new one or the current one can be repaired ?
  • Gr8MP Dec 24, 2007
    Ok . Thank you. I go and look for a used one.
  • Gr8MP Jan 09, 2008
    Yeh
    I finally got a new one and that worked!
    Thanks for your help anyway.
    Genius:
  • 1,601 Answers
Try replacing the Power Supply next.It sounds like it is on its way out.
Please let me know how this works for you.
Thanks
Posted on Dec 18, 2007
  • 13 more comments
  • Thomas Christopher
    Thomas Christopher Dec 18, 2007
    How many ram sticks do you have in there?
    If you have more than 1 take 1 out and/ or switch it around.
    If you have 1, then it should be closes to the CPU.
    Let me know!!
    Thanks.
    Gr8MP, look at your board closely. Are any of the caps. leaking or tops popped up?
    http://cquirke.mvps.org/badcaps.htm
    http://cquirke.mvps.org/csxcaps.htm
    please keep me informed.
    Thanks,
    Thomas Christopher Dec 19, 2007
    Sorry to say that it is time to get a new board.
    If you can get into BIOS, change to default configuration.Or if it is an old board update the BIOS.
    With a memory dump you should be looking at the RAM. Try running memtest to check it. Maybe a bad cap took out a stick
    Let me know!!
    Thanks
    There are some places that check ram. I dont know where you live, you may want to call an electronics store near you.
    Or,
    you may want to get a new one anyway, just for the heck of it..
    Keep me informed,
    thanks
    Thomas Christopher Dec 22, 2007
    Does the blue screen have any error codes on it?
    Does the bios show everything that is attached to your board?
    Thomas Christopher Dec 23, 2007
    Gr8MP, OE is Outlook Express. The part of the disk that Outlook Express is on could be bad. Do you have another disk that you can put in?
    OE comes with Win98
    I am still thinking it is the motherboard.
    Maybe the ide controller.
    I think that you are due for a new one.
    Thomas Christopher Jan 09, 2008
    Your welcome. Thanks for the update!!
How to reset the bios p4 titan ga-8id533 motherboard
As the computer starts up hit the Del key, that will take you into the BIOS utility, once in the BIOS load optimized defaults, this will reset the BIOS configuration.
Failing this just remove the power cord from the back of the computer and take the motherboard battery out for 20 minutes, this will fully reset the BIOS so you will have to input the time and date.
Regards.
Jul 14, 2009 | Gigabyte GA-8ID533 Motherboard
I need to knw wat is the video card limit in GA-8ID533 (Rev 1.1) motherboard
It supports all 4X AGP cards. The max you can get for 4X is 256MB. Nvidia GeForce series has some nice cards for these specs.
Jan 21, 2009 | Gigabyte GA-8ID533 Motherboard
I need to knw wat is the video card limite in GA-8ID533 (Rev 1.1) motherboard?
If you have a 550w+ power supply you can run a Ati Radeon 3850 HD.
P4 2.66GHz 533FSB Problem on Gigabyte GA-8ID533
well if the board support till 400FSb then the 533FSb CPU will not work with the board did you check the website and he board manual that says it support upto 533 bus?
Nov 08, 2008 | Gigabyte GA-8ID533 Motherboard
I HAVE PROBLEM
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1402
There you find all the drivers you need for your motherboard
About the issue whit the memory, are you sure you put in memo-stick comartible whit your motherboard? Check that first!
Sep 10, 2008 | Gigabyte GA-8ST800 Motherboard
Audio/sound
For the Vista compatible sound drivers of a Realtek AC'97 as used in a Gigabyte GA-8ID533, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Gigabyte GA-8ST800 Motherboard
Motherboard
Hi hamideh, your board can Supports up to 3GB PC100/133 SDR-SDRAM Dual memory module DIMM's
Here is the link to your board.
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1402
Enjoy hamideh...
& please vote for me
Mar 08, 2008 | Gigabyte GA-8ID533 Motherboard
Nforce 3a
Hi
I had the same problem. Mine was because of the mainboard capacitors. I quote some part of my post and ones of Tom.
"Nearly one month ago my computer started to reboot again and again. When it came up , after 10 minutes of operation it showed a blue screen showing the progress of dumping RAM or something. Now it does not boot at all. It just turns on and the green light is on , but nothing appears on the monitor. Also there is no drive activity. Just fans work! I think the motherboard is burnt. Any other possibility?"
"Gr8MP, look at your board closely. Are any of the caps. leaking or tops popped up?
http://cquirke.mvps.org/csxcaps.htm"
If yours was like mine , you should just buy the caps and replace them or get them replaced by an semi-expert or something. Good luck and keep me informed.
Dec 21, 2007 | EliteGroup nForce3-A Motherboard
PCI GA-8ID533 V1.1
there is no PCI lock on any retail boards. But there are IRQ sharings and conflicts. Set IRQ to auto, if not, then manualy and if so, then disable a few things, just to free up some IRQs. All depends on the board, best is to consult the manual for the IRQ sharing table and work with that. (disable one SERIAL, IDE port or USB port if you need an extra IRQ) Also check for onboard equivalent to the card you are adding, disable the onboard part...
Dec 27, 2006 | Gigabyte GA-8ID533 Motherboard
Gigabyte GA-8ID533 Motherboard Logo
220 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
