Question about Dewalt 18 Volt Compact Drill Kit
My cordless drill's clutch will not turn 'off' when I select the drill function.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
You drills transmission bump plate, pin and spring are worn. You will have to replace the transmission in order for your clutch to work properly.
Posted on Sep 28, 2009
My Dewalt cordless drill, model DC970, is fully charged and turns. However, when I try to turn a screw, the drill does not move. What should I do?
There is a collar that controls the torque of the driver just behind the chuck. Rotate it until the drill icon lines up for full power.
Mar 05, 2015 | Dewalt 18v Cordless 1/2" Adjustable Clutch...
I can run drill, but it doesnt; have much tork before it goes into clutch mode
there should be different settings for the clutch. there is a wheel behind the chuck which you can turn for the settings. If it is set at the high setting the clutch is worn and has to be replaced.
Mar 27, 2011 | Dewalt DC925 Cordless Drill
Clutch problem on drill??
or it could be as simple as it became loose, open the chuck all the way , look into the hole in the middle,, you'll see a screw head,, tighten it
Aug 03, 2010 | Milwaukee Tool Milwaukee General Purpose...
How do I select torque setting?
the black ring behind the chuck, has numbers on it, turn to desired torque
May 24, 2010 | Dewalt DC750KA Heavy Duty 3/8'' 9.6V...
When i drill with my 18volt cordless, and the bit catches it makes an awful grinding noise inside the drill, its not the adjustable clutch set low. its set on drill?
Your speed switch is between gears, pull the trigger lightly and slide the speed switch back and fourth until it is fully engaged. Also turn the clutch setting all the way down then all the way back to lock it is not uncommon for them to get dodgy.
Cheers,
Kevin
Mar 23, 2010 | Dewalt DC6PAKRA Heavy Duty Xrp 18volt...
How the cordless drill works in drill mode, especially how the clutch works in drill mode, please give the clear explanation with diagrams
the basic operation for the drill working in the drill only mode is you tighten the clutch up which puts more pressure on the spring not allowing the clutch to ratchet like it would in another position therefore bypassing the clutch completely. Give me the brand and model number and I will try and find a parts explosion for you.
Dec 31, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Clutch problems
I dont know where you live but there should be a local industrial distributor aroung and they usuall always have a repair service
Dec 04, 2008 | Makita 12 Volt Cordless Drill/Driver Kit
Drill Turque
Torque, which is measured in foot-pounds, is the drill's maximum amount of turning force. Some drills have an adjustable clutch with different torque settings for different applications.
Aug 27, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Dewalt 18 Volt Compact Drill Kit Logo
228 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
