Question about Sony Cyber-shot DSC-W55 Digital Camera
Autofocus sensor confirmation lights in viewfinder have become ve
The light is very dimm or soft. I tryed clean it. What happened? What can i do?
  • todorandanie Sep 30, 2009
    Sorry,i forget mentioned. The camera is Canon 40D
2 Suggested Answers
chansimon
  • 42 Answers
SOURCE: Canon 40d Autofocus confirmation light damage
1 I suppose this is related to hardware problem.
2 May be the focusing screen is misaligned somehow.
Posted on Mar 07, 2008
My E 620 shutter does not work when using viewfinder, but works when using screen
While using the viewfinder, does any warning come in the viewfinder?
Not sure, but if you are shooting in a different mode, it could be there is not enough light, or the camera can't focus.
Using the viewfinder the camera will use a different way to focus as when using the display.
Perhaps the autofocus, does not work correct. Looking through he viewfinder, wait till the AF confirmation mark lights up. (bottom left)
If it won't light up, something is wrong with the AF.
Feb 22, 2014 | Olympus EVOLT E-620 Digital Camera
Nikon d5100 Blurry photos When I take photos of a party, at night, my photos are very blurry. How can I fix..
Use autofocus if you have a AF lens on it.
Usually you get a kit 18-55 AF lens that has a A/M switch on the side. The switch should be facing the A side so it's set on autofocus. Then you have 9 points on your viewfinder, those are the autofocus points. It should usually be set to center, because you usually want the object in center of your photo to not be blurry.
Remember to press the shutter button halfway and give some time for the autofocus to focus. Then you can press it all the way, you should have your photos nice and clear.
If you happen to have a manual focus lens, you should be watching through the viewfinder and turning the focus ring on the lens and determine if your object is in focus. It's hard at night, but get some practice at home when you have some more light so you get more familiar with the focus.
Dec 26, 2012 | Nikon D5100 Digital Camera
Autofocus canon 600d
There is a seperate sensor for the autofocus. IT is either bad or dirty. You may not be able to clean it either.
Jul 18, 2012 | Canon EOS 600D Rebel T3i Digital Camera
Nikon F65 won't auto-focus or take shots
You're on the right track with oxidation. Try cleaning the contacts in the body and on the lens with contact cleaner, and let it dry. Remove the battery, and clean the contacts inside the camera.
Mar 09, 2017 | Nikon F65 35mm SLR Camera
Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Jan 10, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Mar 07, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
My Canon digital rebel will not autofocus correctly. My camera has 7 points autofocus, but it will only autofocus on the far right point. All other points are not used. I have had the camera for 14 months...
I had this problem awhile ago - you must have accidently adjusted the focal area - it is sooooo easy to do without realising it. Here is what I was told:
Most likely, you have changed the AF point, which only takes effect in the creative modes (Manual, Av, Tv, P, etc)
There should be a button on your camera that has a grid like pattern above it, like
or so. press that, look through the viewfinder, and move the shutter or rear wheel, you should see the different AF points like up in red, and as you turn different ones will light up, and eventually all of them. also, you can look on the screen on top (or back, if its a rebel) and it will show you which ones are selected while in that mode, instead of looking through the viewfinder.
Nov 07, 2007 | Canon Rebel XT / EOS 350D Digital Camera
D50 After autofocusing stops it still isn't quite in focus.
Your diopter may not be adjusted ( adjustment for sharpness of image in viewfinder on the side of the eye-piece ) so set that first and then try again. If this is correct then your camera is focusing accurately ( on the sensor ) but only the image in viewfinder looks unsharp.
Sep 27, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Sony Cyber-shot  DSC-W55 Digital Camera Logo
26 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
