DVD recorder Sony HX525-HDD error
Looks like the Hard Disk drive has given up after 15 months use. Format did not work and it just shows the error or powers off?
Mine did the same at the same time it seems may have been an update gone wrong still looking into it myself its a sata drive iv tride a sata 2 drive in it but that dosnt work but it may need softwere on it
Posted on Dec 30, 2007
    Scholar:
  • 93 Answers
Definately sounds like a shot HDD, best bet take it to someone who diagnostic utilities at hand to get a definitive answer
Posted on Dec 20, 2007
How do I format the hard drive on a Sony DVDs recorder
Why in the world would you want to format the hard drive. It likely has the operating system on it and formatting would leave you with nothing useable.
Feb 12, 2015 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
Sep 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Panasonic DMR-XW350 DVD Recorder: Hard disk is inaccessible to play or delete files. Any ideas please?
Just remove the hard drive and plug into a good working computer and using the Disk mgt area format the drive to erase all. Or if you want to chuck the unit and are concerned about contents, get a nice big nail and sledge hammer and drive the nail through the disk a few times! DONE!
Sep 14, 2017 | Panasonic Televison & Video
HARDDRIVE ERROR ON SONY RDRHXD860 DVD RECORDER
http://www.avforums.com/forums/attachments/blu-ray-dvd-recorders-media/68631d1198812029-succesful-upgrade-hdd-rdr-hxd970-how-upgrade-hdd-sony-x70-series-dvd-recorders.pdf You shouldn't use a computer to format the drive as the dvd recorder will do that for you.
Oct 25, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
When I format my sony DCR-SR68E then it show "unable to format" and its show a time "E 30:00" and when show in my lcd panel HDD format error. Please help me.
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
in left panel extend the events there you will see errors in red right panel you will no what exactly what the error was and at what time it occured you might be able to work your way through the problem
how are you trying to format this usb hard drive it might be listed as a mass storage device
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jul 21, 2011 | Sony DCR-SR68E/S Handycam(R) PAL Video...
How can I copy all HDD's data in LG HDD/DVD Recoder RH1888HS by my computer or Laptop?
If the unit is under warranty...DON'T DO THIS.
open up the unit and remove the hard disk.
If you have a desktop, connect the drive like you would any other hard disk.
If the drive does NOT show up under My Compujter, then the format is proprietary, and all you can do is back up the drive with a program like Acronis True Image (you must have more free space on your hard disk than the DVR's drive size...if the DVR has a 500G hard disk, you need 500G of free space on your desktop drive).
If the drive DOES show up with a drive letter under Computer, then create a directory on the C drive and simply drag and drop all the files from the DVR hard disk (E: or whatever it makes itself) to this folder. The files may still be in a proprietary format and unplayable though.
If you are trying to play the files on the computer, I suggest using VLC player. It plays almost everything in the universe.
Mar 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Sony dvd recorder as hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Nov 11, 2008 | Sony Televison & Video
Errors burning to 1x to 16x DVD-R
I have had much luck recording on off brand 16X discs as follows:
1) Record a "dummy" program on the hard drive, need only about 15 or 20 seconds.
2) Put a blank disk in drive, and COPY that dummy program to disk. Do not finalize.
3) After a minute or so, window will come up and say "Cannot
complete copy."
4) Now while above window on screen, click HOME MENU, COPY, New program list, Select your movie/program to copy, go ahead and finalize, and START.
5) Think you'll find this is successful, however there might be some brands of blank disks that won't work.
6)Let me know if it works for ya. JGIDUSKO@CFL.RR.COM
Jul 04, 2008 | Pioneer DVR533HS DVD Recorder with 80GB...
Hdd error
Jan 08, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Computers & Internet Logo
220 people viewed this question
Alun Cox
David Payne
David Payne
