Question about Canon i450 - Printer - color - ink-jet - Legal, A4 - 600 dpi x 600 dpi - up to 18 ppm (mono) / up to... InkJet
I have a canon i450, for some reason the paper will not go down further during printing. It will only go down about 2 inches and stays there. Then the message will come on saying there is a paper jam. There is nothing jammed. Help!
    President:
  • 787 Answers
Are you sure about there is nothing jammed? I don't think so. In most case there is something which prevent paper. Your printer must be disassembled to see what stop the paper.
Posted on Sep 28, 2009
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Tip
Perform Nozzle Check Pattern of Canon Inkjet Printer without Computer
Models:
BJC3000 and above,S300 and above, i450 and above,Pixma ip2000 and above
Procedure:
  • Set A4 paper in paper tray.
  • In stand by condition,hold down Resume/Cancel button until LED indicator blinks twice then release the button.
Models:
Pixma ip1200,1300 ,1600,1700,1800,1900,2200
Procedure:
  • Power on the printer, immediately after printer standing by press Resume/Cancel button 5 times within 2 seconds.
The printer start printing nozzle check pattern after procedures above performed properly.
on Dec 02, 2008 | Canon S400 InkJet Printer
It won't print anything in color
this is an old days printer. The print head is almost reach to the end of life. Most probably is the print head faulty.
May 26, 2010 | Canon i450 - Printer - color - ink-jet -...
Canon MP210 Paper Jam
A common issue is moisture. As the relative humidity changes, the paper will absorb some of the excess moisture. (Ink jets don't get as hot as other printers; but they do have temperature changes during operation.)
Unfortunately, the only solution that I have ever found is to use paper from a just opened package. Try to keep only enough paper in the printer for a short duration of printing (1-2 weeks). Keep the rest of an open package of paper somewhere else where the temperature and humidity stays fairly constant.
I hope this helps.
Feb 26, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Printer error to insert paper face down.
Have you tried cleaning the rollers, or resetting the printer? See here. For loading paper instructions, see also here. & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 26, 2009 | HP Photosmart C5180 All-In-One InkJet...
Canon i450 uneven printing
The problem could be as simple as your paper not going through the tray straight, or just aligning the print cartridges. Make sure when your paper is pulled through the printer that it isn't getting pulled more quickly on one side than the other. Also, go into your printer control panel to find the 'alignment option' and follow the steps to complete a proper alignment. If that doesn't work, get back to me with more details about the problem. (is it on a slant, are half the sentences printing on a different angle etc.)
Apr 16, 2009 | Canon i450 - Printer - color - ink-jet -...
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
CANNON MP210 e3 SHOWING BUT NO PAPER JAM, C LIGHT FLASHING,B AND LIGHT ABOVE ON,PAPER GOES IN FIST INCH, MACHINE SOUNDS AS THOUGH PRINTING
I think it is not loading paper correctly. May be something struck in the way of roller. Or may be due to insufficient paper.
Another reason may be cover not closed completely.
Let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Canon Office Equipment & Supplies
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon i450 - Printer - color - ink-jet - Legal, A4 - 600 dpi x 600 dpi - up to 18 ppm (mono) / up to... InkJet Logo
old marine
old marine
