Question about Apple iPod MA446LL/A MP3 Player
Ipod quickformat and does not work
I format my ipod on my computer and now it wont go on or off big probleme PLS help
  • frontier1276 Dec 24, 2007
    i have tried to reset my ipod video and it still will not reset i was just listening to music and it quit working
To reset an iPod with a Click Wheel, including: Ipod quickformat and does not work - ipodnano3.jpg ipodclassic.jpg ipodnanIpod quickformat and does not work - ipodphoto.gif= ipodnano.jpg ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Posted on Dec 20, 2007
Please formate the player with your pc
Hi anisnakum
You mentioned you had an Ipod, so use this solution for your problem
Since iPods are basically big hard drives with special software and a screen, the hard drive in your iPod needs to be formatted.
Formatting is essentially the process of prepping the drive to talk to the computer it connects to.
Luckily, you usually don't have to worry about formatting your iPod.
Formatting happens automatically when you first set up your iPod.
If you use your iPod with a Mac, during this process it becomes Mac formatted. Be sure you have Itunes download to your computer
If you use it with Windows, it gets Windows formatting.
If your using a Mac then it will Mac format.
Please take time to rate me
Bud
Oct 15, 2012 | Audio Players & Recorders
HOW TO FORMAT THE IPOD
Hi marksoncaran...
If you want to clear the hard drive...the way you will format it you will double left click on "My computer" when the window opens you will have to find your Ipod amonst the listings...right click on it and select "format"...the follow the instructions
Sep 05, 2011 | Apple iPod Video U2 Special Edition Black...
My ipod wont restore
This is what I did and it worked like a charm:
1. Connect your iPod Classic to your computer USB (I used Windows 7)
2. When it is identified as an external drive, click My Computer to show the devices.
3. Right Click the iPod Drive and click format,
4. Leave the default settings except uncheck the Quick Format box.
5. Start formatting. It takes some time but the blue bar should be moving until format is complete.
6. Run iTunes if it is not already running. Restore the iPod.
It will restore flawlessly.
twitter : @bdfangeles
Aug 24, 2010 | Apple iPod classic 6th Generation Digital...
How to reformat my ipod using itunes?
How to Reformat iPod In order to reformat iPod to work on both Mac and PC, connect your iPod to a Windows computer. Then follow the steps in the how to restore your iPod article. This will reset your iPod and format it for Windows.
Now, resync your iPod with the computer that contains your iTunes library. ITunes will ask you if you want to erase and sync the iPod. If you say yes, this will redownload your iTunes library to the iPod.
At this point, you may also need a way to easily move your iTunes library to the second computer. A quick way to do this is with software that copies the contents of your iPod to a computer. Learn more about iPod copy and backup software here.
Checking iPod Format Each time you sync your iPod, you can check what format it is. In the iPod management screen in iTunes, there’s some data at the top of the window next to the image of your iPod. One of those items is “Format,” which tells you how your iPod is formatted.
Suggested Reading
Mar 27, 2010 | Apple iPod nano
My ipod shuffle wont play music
It won't play music while connected to computer, that's for sure. It only plays when it's disconnected from the wall charger and computer.
The songs could be in the wrong format
AAC is iTunes native format
Mp3 generally works
WMA is iffy - only unprotected (non-DRM) files will work
Streaming songs won't work
-Tha Mp3 Doctor
Aug 29, 2008 | Apple iPod shuffle Second Gen. Silver (1...
The wheel controls are not workin...pls help...
ahhh..maybe you press it hardly...
that's why it will not work..
Jun 02, 2008 | Apple iPod MA446LL/A MP3 Player
I Pod 80 Gb white
try resetting your ipod.. most problems are fixed by resetting it
Feb 09, 2008 | Apple iPod MA446LL/A MP3 Player
How do i sync video's to my I-pod
enable an option called "Include Music Videos" in my iPod settings. Apparently, this feature is disabled by default when you update to iTunes v7.
Jan 06, 2008 | Apple iPod MA446LL/A MP3 Player
Cannot format ipod shuffel
my friend had a similar problem... he was adviced to format using MAC... and it worked for him.....
Nov 11, 2007 | Audio Players & Recorders
Music
Because your problem was published a while ago it may be now fixed but if not read this below.
Have you tryed installing iTunes and running updates?
Well if you've already tryed that try using this software to update it http://www.apple.com/support/downloads/ipodupdater20060110.html
Updating it may remove this error.
If none of them work the next solution is to Format it. To format it not using the software go to "Start" - "My Computer" - look for something called "Removable Disk" click on it just to see if it's actually the iPod then once you've checked right click on it and click on "Format".
If you want to do is using iTunes just plug your iPod in then information will come up on iTunes about your iPod it will give you 2 options update or restore now click "Restore".
Restoring will restore it to it's previours settings and "REMOVE ALL MUSIC AND DATA ON YOUR IPOD".
Good luck. Hope my solution was helpful.
Sep 18, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
91 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Mohamed Ismail
Mohamed Ismail
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
