Question about Epson Stylus CX6600 All-In-One InkJet Printer
Unable to switch on by pressing the power button on the front. It all seems to be connected up to the power supply ok.Help??
    President:
  • 787 Answers
Probably it's a problem in power supply module in your printer.
Posted on Sep 28, 2009
We have two Konica Minolta (Develop) c203s which won't boot up. Both working fine one day, then overnight seems to have frozen. I.e. Turn of the main power switch, the two status lights (Orange and blue)...
Try to Troubleshoot By SWITCH ON MACHINE FROM MAIN POWER SWITCH BY PRESSING UTILITY BUTTON.
-WAIT AND KEEP HOLDING UTILITY BUTTON
-AFTER 10 TO 15 SECOND, TROUBLERESET OPTION WILL APPEAR ON SCREEN, TOUCH IT AND SWITCH OFF.
-NOW ON NORMAL WAYS.
if not ok, then check the panel connection.
- after switching off and on, wait and observe if it display KONICA MINOLTA SCREEN OR Hour Glass symbol.
and let me know for further diagnostic.
Aug 01, 2017 | Konica Minolta Office Equipment & Supplies
F2-1000T Digital Set-top Box.
There are three ways you can connect a DVD player to a TV. Component video gives the best picture quality, but requires 3 cables for the video signal alone. S-video needs only 1 cable but it isn’t as good as component video. Composite video is the easiest connection to make, but gives the lowest picture quality.
Aug 05, 2008 | Televison & Video
LG 42LD560 LCD TV POWER PROBLEM
While you checked the condensers, did you look for faulty connections? places where the solder has a little crack?
And did you check visually, or did you check electronically? In a power supply lots of things can go wrong. More than alone a capacitor with a rounded head.
Jul 11, 2014 | LG 42LG30 42 in. LCD HDTV
My old power supply had 4 wires going to the front panel on\off switch. The Dynex power supply does not support the switch. what do I use to turn the unit on or off. Will the unit function with out the...
Normally the front panel on/off power button and the front panel reset button plug into connector pins on your motherboard.
If you can find a User Manual for your motherboard it will show you exactly where the switch leads plug in on the motherboard. The motherboard's manufacturer and model number will be printed on the board somewhere.
Good luck.
Feb 05, 2011 | Dynex DX-400WPS 400-Watt Power Supply
I'm connecting everything but the motherboard does want to start
Some power-supplies have a rocker-switch, with a '|' and an 'O' icon, which acts as a "master" power-switch. Be sure that you have pushed down on the '|' side of the rocker. As you do so, look at the motherboard -- it may have a small green lamp on it, to indicate that the motherboard is receiving power from the power-supply. Also, look at the fans -- they may slightly "rock" (twist back and forth) for a moment as you move the switch.
Most of the connections to the front-panel can be ignored while "trouble-shooting" your problem. As long as the two "power" pins on the motherboard are connected to the "power" button on the front panel, pressing the "power" button should work as expected.
Oct 26, 2009 | Asrock AM2NF6G-VSTA Motherboard
L440Gx server board do not boot
1: Check wether the on/off button on your power supply is turned to on.
2: Check your cables. Try switching with those from other pc's.
3: Check wether all the connections from power supply to the mainboard/ram/video/harddisk are OK.
Hope this helps,
Yannick
Feb 18, 2009 | Intel Server Board L440GX (KMS440GXTPAK10)...
New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Nov 18, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Won't turn on - dead dead dead
I since the problem is a stuffed battery ort else the power pack has ceased to exist. One thing is the way you have explained it seems the Laptop is ok try and find someone with a another powerpack maybe the battery ok it seems to me the pack has poked? Goodluck I wish all the problems seem simple like yours.
Sep 02, 2007 | Toshiba Satellite M45-S169 Notebook
Epson Stylus CX6600 All-In-One InkJet Printer Logo
242 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
