Question about Samsung SGH-U600 Cellular Phone
Phone won't charge. Charger is working but phone won't take charge.
  • 33 Answers
SOURCE: charger pins broken
Charging socket needs to be replaced. smart11 is right, is pads are broken on the board, you can't do anything. Damaged charging connector can make a short in the phone, what can cause short battery life, no audio and other problems. So if there are shorted pins in the phone, even you will charge the battery out of the phone, the short inside the phone will discharge it really shortly. The reason why they don't want to replace the connector is, that it is not very easy to replace it by hand, just with hot air. They don't want to risk, that they will damage your phone more, than it is now. If you are from UK, check: CRC Group - Nottingham,they can do it. It will cost you 40pounds. If they will brake the phone, they will give you refurbished and tested one.
Posted on Sep 29, 2007
SOURCE: my phone wont charge
i have the same exact problem thats how i ended up on this site
Posted on Jan 04, 2008
check your charger first, if charger is ok then check the charging connector on the phone, clean it with a toothbrush and solvent cleaners.
Posted on Mar 27, 2008
DR NITIN
  • 221 Answers
SOURCE: phone not charging
Take it to the Service Center. The Internal Charging Port has malfunctioned.
Sahaja Yoga is the ONLY SOLUTION to all the Problems of World.
Posted on Mar 31, 2008
SOURCE: phone not charge.
right this happened to me too
its the charging port the pins in it are crushed and when you put in a charger it just pushes them of the plastic so they cant charge
basicly it the charging port
Posted on Feb 20, 2009
My phone shut off and won’t turn back on. I cannot remove the battery with the ZTE Max Z981
Check up battery is fully charged.or charging when charger in plugged in.If not charging check up charger working with some other phone .
If the battery is old enough replace battery or check up micro usb in phone thro' mechanic.
Oct 03, 2017 | ZTE Cell Phones
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
Mar 19, 2013 | Blueant Ant S4 Handsfree Voice Controlled...
The phone won't turn on
Try replacing the rechargable battery inside that phone.
Jan 12, 2013 | HTC Amaze 4G Smartphone T-Mobile
Just charged my new phone but it shuts off and won't work when I unplug charger
Are you shure your charger is working properly? Or that the battery is not shot?
Oct 21, 2012 | Huawei Cell Phones
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
What do u do when your phone won't charge even
charge your battery on another phone and then place your battery in your phone and switch on your phone and connect the charger to it if still it isn't charging then check your charger and if the charger is ok then you need to repair your phone manually or by taking it to authorized dealer
Apr 25, 2012 | Cell Phones
Phone wont charge so will not turn on
Have you tried more than one power outlet? It could be the power outlet you're trying to use isn't functioning. If it won't charge on a different outlet, the issue is either the charger you're using or the phone itself. Try wiggling the charger around while plugged in to the phone, see if that will charge it at all. You should also trying getting a different charger and see if that will work. If not, you may just need to replace the battery/phone.
Aug 14, 2011 | Ericsson Cell Phones
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
Samsung SGH-U600 Cellular Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
