How to adjust automatic anti skating system on a PE 2015 record changer? Had to replace magnetic cartridge and needle by an other system, and the arm pulls too much towards the external side of turntable. Anti skating system is said to be automatically adjusted with arm weight. There seems to be a screw on top of arm mechanism, but it is tight and I'm not shure it is the right thing to adjust. I was looking for a service manual which could help.Thanks for an advice!
  • Audio Player... Master
  • 1,908 Answers
Elektrotanya for electronics experts search for the word processing that will change to GET MANUAL after a while you have a manual but there should be a tool neccesay for the arm or Tone arm geometry knowledge or almost there was a tool for the novice user there delivered with the turntable because the error angle setting for the needle special if you replace the complete element with needle
Posted on Jun 11, 2017
5 Suggested Answers
SOURCE: skating
i have the same issue with my sl 1200 mk5s i slightly adjusted the top screw on the tone arm and it has been working fine since..... If you do decide to adjust it MAKE SURE U DON'T LOOSEN IT TO MUCH. Only a hair at a time
Posted on Nov 04, 2008
landsend
  • 1066 Answers
SOURCE: Needle Skates
don't scratch as it's the worst thing you can do for a turntable and for the record.  Buy a scratch pad instead.
Posted on Mar 21, 2009
joedirty
  • 158 Answers
SOURCE: the needle is skating across the whole album.
When I was young I taped a penny on top of the head above needle.Those were the great days 45's rules.
Posted on Dec 27, 2009
Grubhead
  • 5449 Answers
SOURCE: I have a Kenwood KD12R turntable. How do I set the
The weight should be set to the position recomended by the cartridge maker. Typically 1.5 to 2.5. If you don't know the makers setting, set it at 1.5 and work upwards. The stylus should track nicely in the record groove and not jump. But not too heavy as to cause rumble in the sound. Set the skate control low and again try the record out, if the stylus starts to skate accross the record increase the force. It's a case of experimentation with no fixed rules on these settings. Some records might need adjusments afterwards.
Posted on Feb 15, 2011
I have a Kenwood KD12R turntable. How do I set the arm and needle. I have a weight with an adjustable dial at the end of the arm and a separate anti skating dial on the base of the turntable? Regards -...
Feb 15, 2011 | Kenwood KD-291RC Turntable
All the arm does whenever I try to play a record is move across the record. This even happens with a brand new needle. I'm ready to get a new turntable.
there is a counter balance on the side of the arm called an anti skating weight.it prevents the grooves on the record from pushing the stylus inward,wearing out one side.when the anti skate weight system has a fault,it drags the arm toward the center of the record faster than needed.there is also a weight on the back of the arm.that is the balance.when set to zero,the arm should balance.then the weight is turned to 1 gram or so.if there is not enough force downward,the anti skate mechanism will drag the arm inward.
Oct 28, 2010 | Audio Players & Recorders
My technic 1200 mk2 skips records, i tried other needles and adjusted tone arm. Even tried pennies on cartridge
Ensure that the turntable is sitting as flat as possible and does not allow any external vibration to penetrate.
Also try operating it without a record on it make sure that the plate is turning smoothly without interruption and also does not have any vibration.
Nov 23, 2009 | Technics SL-1200 Turntable
Tone arm gets caught up and skips repeatedly
Is there a counterweight on your arm or is the an adjustible spring setting? You need to move the counterweight toward the needle. You dont need much but the needle end needs to be heavier than the back side. If your anti skating is a magnet ... reduce the force on that as well.
Let me know what happens.
a
Sep 25, 2009 | Audio Players & Recorders
Needle skipping & not pushing down
There should be an "anti-skate" adjustment to control the arm moving across the record. It is possible that lubrication has stiffened up as well. This unit may need a general overhaul/cleaning.
Dan
Jul 20, 2009 | Technics SL-1210MK5 Turntable
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Adjustments on Technics SL-B2 Automatic Turntable
the pitch is just the speed, adjust to your liking.
"How do I adjust tracking pressure and anti skate?
If you are lucky enough to have these two adjustments here's how: Move tracking force counter weight till needle suspends/hovers above record. then rotate numbers to zero. (this is zero grams pressure on record) then rotate weight AND numbers to recommended tracking pressure for your needle usually 1.5 to 3 grams is average. Then rotate anti skate to be equal. That should get you there. If you still have adjustment related distortion then it may be time for a new needle.
NOTE: Anti skate is adjusting side to side pressure WITHIN GROOVE of record. Tracking pressure is how hard the needle is pushing down inside the groove." from
turntableneedles.com/FAQs_ep_33.html
lots of crackles are caused by crummy records and needles. to some small degree are unavoidable no matter what, but above all the records must be clean.
someday the manual may show up for free here
http://www.vinylengine.com/library/technics/sl-b2.shtml
Dec 02, 2008 | Audio Players & Recorders
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Re:
Hi Vat,
Although I live in Canada now, I was born in the former
Czecholsovakia. While I spent a year in the Czech Republic in
2006, I was amazed how advanced their technology was, in
comparison to Canada or the US. If you want modern technology,
Prague is the place to go. Anyway ...
1) As I said before, do NOT adjust the tone-arm weight up
and down. This setting must be set to match the stylus and
the cartridge !!! The wrong setting is very bad.
To get the weight adjusted correctly, do the following.
a) Check the cartridge and stylus (needle) specifications, on
the WEB if necessary.
A typical tracking weight is between 0.9 grams to 1.5 grams,
but this very much depends on the needle geometry. To much
weight will damage the needle and the record, but
so will too little, because the needle will not stay on the
surface, skipping or mistracking on loud passages.
Note that the tracking acceleration is proportional to the
the square root of the loudness, multiplied by the frequency
squared. So if the tracking force is too low, the needle will
bounce over high frequencies and damage the record as
well as the needle's tip.
2) Once you know the correct force for your needle, adjust
the rear weight for ZERO force, such that the needle just
floats weightlessly in the air. If your turn-table has an anti-
skating adjustment, set that to zero as well.
3) At this point the tone-arm should be totally weightless,
and should neither touch the plater nor swing up/down
by itself. It should float halfway.
4) A this point, adjust the rear weight's dial (not the weight) to
read zero. Note that the dial will slide, while you hold the
weight still. You have now calibrated the tone-arm's zero
point.
5) Now, adjust the weight (with the dial) to read the desired
tracking force, for example 1.25 grams.
6) Now adjust the anti-skating dial to the same number as
the rear weight. This setting compensates for the radial
(towards the center) component of the friction vector,
caused by the needle riding on the record groove, at some
specific (average) tone-arm angle.
7) Your tone arm is now balanced, and you should not
touch it after this, accept for minor adjustments.
For brand new records, you may lighten the tone-arm
by 10%. For old records, you can make it a little heavier.
Similarly, you can adjust the anti-skating to prevent a
record from skipping, but a bad record should be played
only once (and stored on your computer).
8) For some tone-arms and cartridges, the cartridge pitch
(up/down angle) is also adjustable. This requires a special
jig or gauge, supplied by the cartridge manufacturer.
The pitch can be adjusted either by the use of screws or
wedges, and by lowering / raising the rear gimble. On my
Technics SL 1200, the gimble elevation is adjustable with
a large ring, and my SURE V15 cartridge came with a guage
for adjusting it correctly.
9) It may also be possible to adjust the cartridge's yaw and
radius, but all of these adjustments should only be done
using the correct gauges and by strictly following the
cartridge installation manual.
10) NONE of these adjustments should effect the tone-arm
cueing or return process. There should be plenty of
clearence if the cueing mechanism is working properly,
except, perhaps, for the gimble elevation, if the cartridge
is unusually tall.
11) Is the cuing mechanism (i.e. the tone-arm lifter)
mechanical or hydraulic ?
Is it the lift consistent or does the tone-arm drop down
with time?
Does the tone-arm move parallel to the plater, or does the
stylus height change with tone-arm position (yaw)
You are looking for a mechanical defect in the cuing
mechanism.
12) How much over all lift do you get between the down position
and the up position? This should be at least 8 to 15mm
If the cuing mechanism is worn out, it may not move enough.
If it starts too low, it may move enough but not raise the
needle enough to clear the record.
If the cartridge is tracking too low, you may have to
remove some wedges or spacers between the cartridge
and the head, or lift the rear gimble if it is adjustable, or
get a different tone-arm head, that matches the cartridge
profile.
Finally as silly as this sounds, make sure that the
platter is fully dropped and properly engaged. If the
plater is too high, for what ever reason, this would also
cause the needle to drag.
Also make sure that the rubber mat on the plater is the
right one and that it is not too thick.
Martin
Jul 02, 2008 | Audio Players & Recorders
Marantz TT221 turntable anti-skating problem
Hi, sounds more like tje stylus tip is gone and therefore the needle isn't holding to the grooves rather than a tracking weight or anti skate problem. Styluscity@gmail.com
Mar 27, 2008 | Marantz Reference TT-15S1 Turntable
149 people viewed this question
 Grubhead
Grubhead
