Question about Hotpoint Ultima WF860 Front Load Washer
I have just taken a load out from my washer and most of it is covered with a greyish slime, which is also splattered over the glass door at the front. The machine was definately not overloaded. I have wiped around the door seal which also has this muck on it. Is there a filter which should be cleaned out, as there was on my previous machine? There is nothing in the handbook. How do I get rid of this please??
    Genius:
  • Hotpoint Master
  • 1,460 Answers
The filter is located near sump hose it is a filter though does not look like one...Check sink drain too as it may be purge back from this...
Posted on Sep 28, 2009
Testimonial: "Did this and cleaned the filter which was disgustingly clogged up! Many thanks "
I have water coming from the detergent tray and the bottom of the washer door what could be the problem
Posted on Jun 16, 2011
Next question, how do I get the slime out of the clothes from washer?
Cleaning the rubber door gasket will not get rid of the slime issue. The slime comes from buildup on the outside of the washer drum. There are two causes for this. First, if you always close the washer door after use, then the moisture inside the drum cannot dissipate and the slime can form. Also, using the wrong type of detergent (or an excessive amount of the correct detergent) can cause the slime. There are front load washer cleaning products that you can purchase and run to clean the slime from the outside of the drum.
Dec 15, 2014 | Washing Machines
OVEN GLASS INSTALLATION
MODEL #TES356TD SERIAL RWO0415338 ESTATE
Jan 17, 2014 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
Front door is leaking..I think there is gunk under the grey seal..can that be taken off and cleaned or anything?
If the door glass and the door seal are making proper contact there should not be a problem..The smallest gap, split or tear will let water out. A leaking door seal usually needs to be replaced by a tech....Nomess
Apr 02, 2010 | LG WM2487H Front Load Washer
The gasket at the front door collects water and turns to dark slime in our other wise nice LG front loading washer What is there to be done about this dirty & slimy problem
you may need to replace the door gasket .. it may be sealing properly. that green slime you speak of i s called algea, same fungus found in swimming pools.. you can use algicide to remove it . Pleas were gloves
Oct 11, 2009 | LG WM-2277HW Front Load Washer
Food splatter behind screen on door of microwave
If you take the glass out you have to find a deaker or someone who the tools to check for leaks around the glass.
Mar 17, 2009 | GE JVM1640 Microwave Oven
Removed splatter shield
The parts can be ordered from the Panasonic authorized parts rep. You have to contact Panasonic for details.
I strongly recommend to have any work on a microwave oven done professionaly. There are radiation leakage issues if the door is not re-assembled properly. After doing any service the microwave oven must be tested for radiation leaks. I doubt that you have the radiation testing equipment to make sure that there are no leaks.
From US Food and Drug Administration (Microwave Oven Safety)
http://www.fda.gov/cdrh/consumer/microwave.html
Excellent Wikipedia Article About Microwave Ovens
http://en.wikipedia.org/wiki/Microwave_oven
Jerry G.
Jul 26, 2008 | Panasonic NN-S753 Microwave Oven
Dirty Door Glass inside the choke - how do I clean it?
Its very hard to take apart the doors They normally have a lot of screws. May have a plastic snap on cover that's covering them up. Some of them are even sealed and can not be taken apart.
Anytime you work on a door you must check it with a microwave leakage meter. The door has metal gaskets and a screen that blocks the microwaves upsetting them will cause it to leak.
This is not a do it yourself repair.
Dec 24, 2007 | GE JVM1870 Microwave Oven
I am currently fixing my microwave, which has done the same thing. Go to http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60AMicrowave
just select your brand and under parts, select doors and handles. It will be called Door film, peel & stick. For my microwave, it runs from $16.00 to $21.00. Seems like a very easy fix.
Nov 09, 2007 | Microwave Ovens
Hotpoint Ultima WF860 Front Load Washer Logo
111 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
