Question about Pioneer Car Audio & Video
Can I get a wiring diagram for the pioneer CD 635
Can I get a wiring diagram for the pioneer CD 635 active crossover? I am getting no sound except noise. at the input terminals I am getting a voltage reading of 6V.So I am guessing there is a problem with the input stage IC. Can you help?
  • 13433 Answers
SOURCE: Bosch Dishwasher SMU 2046
It doesn't work at all If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Oct 20, 2008
robotek
  • 1512 Answers
SOURCE: pioneer a858 amp no sound
Hi Big John
This is a nice reference series amp with a decent phono preamp stage. It is unusual to see a phono stage get damaged in this way.... but Murphy's law tells us "If it can be blown up, then someone will do it". I recommend that you do fix it. First up, perhaps check the settings for the preamp on the rear of the amp(from recollection). Be sure that you have it in moving magnet (mm) mode if you are using a MM cartridge.
Although its been a few years, My recollection is that there is a separate power supply for the phono preamp, with maybe even power regulators on on the actual preamp board. First check would be here to see if both DC rails are present for the phono Preamp stages. Most common failure here is heat stressed cracked/dry solder joints.
You need a good HiFi/Audio tech to have a look at it for you if the problems run deeper than DC supply for the preamp. Good luck. A FixYa rating is a great reward for my time to address your problem. Cheers
regards
robotek
Posted on Nov 07, 2008
  • 74 Answers
SOURCE: Wiring diagrams for installing tweeters and crossovers in a door
try 12voltresource.com or google "wiring diagrams for car audio"
Posted on Feb 17, 2009
  • 68 Answers
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Posted on Nov 17, 2009
  • 6 Answers
SOURCE: need speaker wiring diagram for DEH-15 pioneer cd player
left front +white,-white/black
right front +grey,-grey/black
left rear +green,-green/black
right rear +purple,-purple/black
Posted on Feb 22, 2010
A pioneer gr-333 graphic equalizer which is labelled on back side; all input and output is written on tape only..Can i connect a cd player on this terminal?
Yes, connect to TAPE PLAY.
Then you come out of EQUALIZER OUT to your sound system.
There are other ways to do this, but it all depends on the rest of your system.
DOWNLOAD THE MANUAL FROM THE NET.
Peace-
Jan 04, 2016 | Pioneer Audio Players & Recorders
I have pioneer sx 20 tuner/amp and behringer ultragragh pro fbq 1302 graphic equaliser linked together with mono cables via tape i/o rca ports lights on graphic eq lights in sync with sound on sliders but...
It is a bit fuzzy for me, how everything is connected, but just plugging in cables where they fit won't always work. Special not with tulip plugs and cables.
Not sure you Amp has speaker switches, but you could start there. NEVER switch on an amplifier, while the volume button is open. Not even when it is half way. Please every time you want to change something, first lower the volume.
First try to get any sound from the amplifier in the speakers. When you have something like noise in the speakers, then you can test an input on the amp. You could put in a pice of wire in and choose the correct input button and then turn up the volume.
If it starts humming, you are on the correct input. On that input you plug in a device giving enough power (voltage must be within the range for that input) and check if it works.
When you want to know anything about voltages going in an amplifier I add a wiki page, and for all other inputs you can find the levels on Wiki too.
Line level Wikipedia the free encyclopedia
Jan 27, 2015 | Behringer Audio Players & Recorders
My 1998 land rover discovery i replaced the stock cd player with a pionner after market cd player everything is hooked up properly but cant get sound
Oh... Pioneer may be bad. I had a new tape player that was broken the day I bought it. Pioneer did replace it.
Apr 28, 2013 | Cars & Trucks
Hi! I have a Pioneer VSX - 415, but get the message "Overload" as soon as I turn the volume up just a little. What can I do?? Eyvind
There are several things you can do, but taking the simplest things first into consideration.
Wiring. If you have any loose speaker terminal connections at either end, or any stray strand wire near the receiver chassis it can cause this problem. It's likely that this is actually NOT the case in your particular situation as it appears to be volume control related, but this condition will also cause an overload message as well.
Speakers...lack of efficiency/sensitivity, high or otherwise unstable Ohm rating will require more power. Ohm ratings are based on a nominal impedance (resistance) of a specified input voltage by industry standards, and can vary considerably with signal frequency. Higher impedance occurs as input frequency is decreased...more on this later.
System setup. How many speakers are connected? Each terminal is designed for one channel connection. If you have multiple speakers, i.e.; spliced in series such as with separate enclosures that have multiple drivers, this increases the resistance and power consumption dramatically.
After the above considerations are addressed and resolved but you are still experiencing the problem, do one or all of the following;
Check your audio configuration. If your system has an equalizer, loudness control or "bass boost", turn them off. More bass requires more power from the amplifier, thus can be a cause of the overload you are experiencing.
Adjust your crossover. If you are using an active subwoofer, increase the crossover frequency point in the speaker setup menu of the receiver. You may or may not have to set your other speakers' setting to "small" to enable the digital crossover feature, but setting them to small is preferred in your case. This will allow the subwoofer (if an active one) to handle a broader spectrum of the bass frequencies, rather than the speakers that are being powered by the receivers' amplifier that is currently being overloaded. It will also improve the sound quality. You however, do not have to have connected nor use a subwoofer to do this type of setup, simply increasing the crossover point will omit some of the lower frequencies that are putting higher demand on the amplifier. Alternatively, you may also increase the crossover frequency at the source material, such as your CD or other player instead of in the receiver.
Dec 12, 2010 | Pioneer VSX-415-S 5.1 Channels Receiver
Need wire diagram for pioneer eq-6500
Pioneer EQ-6500 9-Band Car Equalizer .i want to buy this equaliser.i need 10 pieces ,please send me through my email febiano22@yahoo.com
Nov 24, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
Need plug wiring diagram pioneer deh-46dh
Orange-12v all the time
Red-igintion switch
Yellow- to lighting switch terminal
Black- chassic grd
Green-front L spk +
Green/black -front L spk -
Gray - F R +
Gray/black- F R -
Green/red- R L +
Black/green- R L -
Gray/red- R R +
Black/gray- R R -
Blue- Control to power amp if using.
Apr 10, 2010 | Pioneer DEH-46DH CD Changer
RADIO CUTS OFF WHEN VOLUME IS TURNED UP
It could be your wiring as well. Sometimes, when speaker wire gets cut and grounded, like your factory wiring to your door speakers or you tap into facrotry speaker wires to add more, the load on your deck increases. When the volume gets to a certain level, it will cut off because of the heat produced to maintain the load.
Feb 23, 2010 | Pioneer DEH-P4000UB CD Player
Wiring diagram for power input
What power input are you hooking it to? Do you mean how to wire it? Or hooking up amplifier?
If you want a user manual and installation manual, you can get them here:
http://www.generalmanual.com/Players/Pioneer-DEH-P2900MP-In-Dash-CD-MP3-WMA-Receiver.htm
Jan 25, 2010 | Pioneer DEH-P2900MP CD Receiver...
I have a Pioneer DEQ-9200 DSP Audio Processor
are your power wires and your rcas on oppsite sides this may be your problem
Oct 27, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Car Audio & Video Logo
266 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
