Question about Motorola Mobility MOTORAZR2 V9 Cellular Phone
Screen went multicoloured yesterday, now it seems to be ok.
Screen is now half hidden by what looks like a multicoloured barcode
If it doesn't clear after a reboot, you cancheck where the issue is by using an external display. If the external is OK then the laptop display is faulty. If it is also showing issues, you have a GPU fault.
Nov 23, 2013 | Samsung NP-N130-JA01US Netbook
My acer z5600 crashes with multicoloured screen when playing games
Ya it sounds like your video Card is dying, though you can check with different RAM and try some normal games which don't need high Graphic. You have PCI Graphic card fitted on it then try removing and playing the game, then this way you can know what is the fault.
Aug 14, 2012 | Acer Aspire Z5600 PC Desktop
Hello i was on youtube my samsung netbook nc10 just went fuzzy and now has a white screen with multicolour lines, what can i do, i have tried to open in safe mode doesnt work. Many thanks
Your graphics card or monitor has failed, If it is under warranty you should be able to get it repaired or replaced. Otherwise take it to a qualified computer repair shop for repairs.
Apr 06, 2011 | Computers & Internet
N70 display white please solution mee
Dear friend:
First get the lcd checked
Second connector of lcd
Third display driver crystal IC
Fourth get the smps ic power controller checked
Fifth get the line checked (lcd ic to lcd connector)
and last get the omap (cpu) checked
Nov 25, 2009 | Nokia N70 Cellular Phone
Nokia 6500: Dodgy screen?
simply check the connections of the lcd to the board... or just tighten the screws... i had repaired a phone of that problem and this was my solutions.
May 31, 2009 | Nokia 6500 Slide Cellular Phone
The Right Half of My Screen Is Grayed Out
It seems unlikely that two pins would be missing. They would more likely be bent down. If there's no bent pins, it looks like it could be a faulty monitor. Certainly, when TFT displays go, they tend to manifest the fault in a colourless or multicoloured bar consistently across a portion of the screen.
Feb 04, 2008 | ViewSonic VA721 17" LCD Monitor
Motorola Mobility MOTORAZR2 V9 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
