Question about Intel D845GVSR Motherboard
How to connect internet & lan softwares in my pc's
  • 121 Answers
From cd givn with it
Posted on Oct 25, 2009
How do you get the ezbook pc windows embedded CE6.0 to connect to internet via dial up. Have a service, pulgged it up and unable to connect.
Dial up requires a modem instead of a LAN card. It uses an RJ-11 phone plug and not the bigger RJ-45 LAN plug. You also need a dial up internet service provider, and possibly software to make the phone call. There is a Connections setup in Internet Options, under Control Panel if you don't have the software.
So, you are right on track. Just make the call and enter the user name and password to finalize connection.
Dec 07, 2012 | CTX EzBook V92C266 Notebook
LAN card no longer recognizable after software download
So your Cable Ethernet works,but your WiFi doesn't? OR? Anyway go to device manager an uninstall the LAN/WiFi, whichever one isn't working, but not BOTH, and remove connection & reboot, at next boot, if OK it will find drivers and reinstall. If it cannot find drivers you will need to download them from ACER,and install & reboot.
Feb 27, 2010 | Acer Aspire 5610-4648 Notebook
No internet connectivity after upgrade firmware
1,there is a reset button
2,press this using any pin with power
3,automatically restart
4,connect your router with pc
5,type 192.168.1.1 on the browser
username:admin
password:admin12 or admin
configure router
enable dhcp
Oct 29, 2009 | D-Link DSL-G604T Wireless Router
I can't connect my internet because i don't have network drive and ports(COM & LPT) how can i get the software
You can connect your internet from your Lan card first of all check your pc
lan card is here or not
after then you can connect
other wise you can connect your internt from the usb port
Sep 12, 2009 | Computers & Internet
I have linksys wireless-G 2.4Ghz broadband router connected to a pc. My wife bought a MAC and wants to get rid of the PC. Is the router compatible with a MAC? If so how do I download the software to set it...
Hi! Absolutely, the Router is OS independent. All you need is a computer with a properly configured Ethernet LAN adapter and a web browser to configure the Router. Any platform that supports Ethernet & TCP/IP is compatible with the router. You may need to provide additional hardware & software (i.e. Ethernet cards and/or software drivers) to ensure that all clients operate with the router.
By default of your mac computer it has already a buil-in LAN port same as your pc and it should be properly configured. just connect the cable from the mac lan port and the other end goes to your port 1 to 4 of the linksys router and it should give you an internet connection. if there is no internet access, pls check the ff:
1. Go to system preferences, network
2. It will pop up the network window
3. location set it to automatic
4. show - set it to built in ethernet
5. once you set it to built in on the lower portion it should set to tcp/ip and the ip address should show, once there is an ip address, you should get an internet connection, sabe or apply the settings
6. you are going to do the same thing if you are going to set the pc on a wireless connection.
if you have any querry pls feel to get in touch..
Aug 16, 2009 | Linksys Wireless-G Broadband Router
I have a new Macbook pro and when I attempt to set up a network I get a message that the connection is "timed out" I cannot seem to establish a network with either DLink or Lynksis Any suggestions?
By default of your mac computer it has already a buil-in LAN port same as other pc and it should be properly configured. just connect the cable from the mac lan port and the other end goes to your port 1 to 4 of the linksys or dlink router and it should give you an internet connection. if there is no internet access, pls check the ff:
Aug 16, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-Link DES1008D 8 port fast ethernet desktop switch
By using it, of course you have this items to connect it with internet:
  1. UTP Wire with Connectors at end each PC or Client Workstation.
  2. Make sure every PC or Client Workstation have its own LAN Card.
  3. To connect on the internet is to know what is IP Address, Gateway Address & DNS Server Address settings on your LAN connection.
  4. Lastly, It should have internet provider in your place.
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Need to know how to install lan card
yes its plug & play device, actually your system can detect such device like your new LAN card. The device is still on your Device Manager but not totally working, need to install first its software to run that new LAN Card.
If you don't what kind of your new LAN card, just install a program that identify the name & model of your LAN card device. Here is the link to install that freeware software www.astra32.com run this program to diagnose the system and identify of your new LAN card device. Good luck!
Jul 25, 2009 | IBM (02K2776) Pentium II, 350 MHz...
LAN to LAN Connection
try to use the the teamvier software and install it at boot server or pc you want to access for the other site, remember you need to intall too at the other site the software and take down the id number and the password
Jul 20, 2009 | Computers & Internet
Intel D845GVSR Motherboard Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
