Question about Nintendo DS Lite Console
Nintendo ds lite touch screen protective outer layer(plastic)
My outer plastic cover for my touch screen is scratched up, but my touch screen works fine. can I replace just the outer plastic protective cover?
  • 24 Answers
You must send it in to Nintendo, for a new touch screen or take it to your nearest GameStop video store.
Posted on Dec 19, 2007
Can you repair the finish on the screen, its all blotchy
Two things to try:
You can take the screws out of the back of the unit to get to the back of the screen. On 951XDs the outer screen is just a protective cover for the actual LCD and its typically glued onto the front cover with an adhesive.
Once you isolated the screen away from the rest of the electronics then you can clean it with "Novus 1, 2, 3 Kit Plastic Polish and Scratch Remover" (find on Amazon).
The plastic used for the cover of the 961XDs are typically alcohol resistant, the chances are that someone has used acetone instead!
Apr 26, 2014 | Northstar 951XD GPS Receiver
My lg encore touch screen will not respond to any touch. the power button, volume button, the camera button, and the charger all still work, but no matter how many times, or where you touch the screen, it...
Displex Touch Screen Polish is perfect to protect screen of your Smartphone. Tired of a smeared, dirty, scratched up touch screen? The Displex Touch Screen Polish is the simple solution for this problem most smart phone users have. This new special polishing paste gives you the ability to mask off apertures in the display. It will make a layer of transparent protective film on your screen. Safe and made specifically for touch screen phones, the displex paste will not damage your touch-screen.
Features:
  • Displex Touch Screen Polish is perfect to protect screen of your Smartphone.
  • The Displex Touch Screen Polish is the simple solution for this problem most smart phone users have.
  • This new special polishing paste gives you the ability to mask off apertures in the display.
  • It will make a layer of transparent protective film on your screen.
  • Safe and made specifically for touch screen phones, the displex paste will not damage your touch-screen.
  • It protects your screen from dirt and dust.
  • Antistatic and reduces fingerprints.
  • Perfect for touch screen phones, touch screen devices and tablets.
Specifications:
  • Type: Screen Polish.
  • Scratch-proof.
  • Invisible protection.
  • Manufacturer: Displex .
May 05, 2011 | Cell Phones
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Badly scratched bottonm screen-
The bottom screen of the DS Lite is made up of 3 parts. The LCD Screen which provides the pixel images you see. The Touch Screen which basically is a piece of plastic that sits on top of the LCD portion picking up the touches from your stylus. And a protective shield layer, to protect from scratches. They are all glued together so unless you are looking, you would just think they were one screen.
If its just scratched up, you really only would need to replace the protective cover, because the Touch Screen and LCD Screen should be unscathed beneath it. However, if for some reason, you don't have that protective cover, or you just want to replace the screen anyway, you have options. You can buy the Touch Screen alone (attaching it onto the already owned LCD screen), or with a new LCD screen attached. As far as the protective layer, I haven't done enough research to know if you can buy them or not, but they do sell plenty of different kinds of screen covers that you can just stick on, which I am sure would be a fine substitute. My price estimate for the Touch and LCD Screens together would be anywhere from $5 to $20.
If you decide to replace the entire screen, I urge you to know exactly what you are getting into. Follow guides, know the parts, and have the tools you need. When opening up a device like this a lot can go wrong that you were not counting on, so take care.
When I fixed my own DS Lite, I found that it was very helpful to watch demonstration videos ahead of time, so I knew the steps, and when actually working on it, making sure I had guide available.
Here are some videos and guides you can look at to make sure you know what the project entails, as well as how to go about it:
http://www.youtube.com/watch?v=fJ3W6Y9zTQY
http://www.pwn3d.us/archives/440/
http://site.powergamingparts.com/RepairNdsl.html
http://www.flickr.com/photos/retroleum/sets/72157605949769269/ <-- This is more for just extra reference pictures
There are probably better guides out there so do some research on your own as well.
I hope that helps.
Jun 17, 2009 | Nintendo DS Lite Console
My screen on my lg kg800 is scratched how can i replace it with a new one
is the actual screen inside scratched or is the outer phone housing screen cover scratched? There is a difference. The actual LCD screen is inside the phone housing and is protected by the phones housing. If the actual LCD screen somehow was scratched it can be replaced very easily and usually inexpensively. Try Ebay for the LCD. If the phones outer clear housing is scratched you can also replace the housing either by purchasing the same phone used and using its housing or some "dummy" phones can be used for there housings also. If the scratch is not really bad I have used rubbing compound to remove fine scratches, good luck!
Sep 03, 2008 | Cell Phones
I HAVE A POLAROID a700 DIGITAL CAMERA WHICH HAS ITS LCD SCREEN 9 (OUTER, STICK ON)BADLY SCRATCHED. WHERE CAN I GET A REPLACEMENT, PLEASE?
No replacement available.
protective cover is the most likely option
http://www.google.co.uk/search?q=LCD+screen+protection+patches&sourceid=navclient-ff&ie=UTF-8&rlz=1B3GGGL_enGB260GB260
Aug 20, 2008 | Cameras
Scratch on camera's LDC screen
do you mean the plastic cover has become scratched or the screen itself is malfunctioning?
If the screen is malfunctioning return it.
If you have scratched the screens protective cover there is a great product called "displex" (i buy it off ebay) buy it with the special cloth, Its a very fine abrasive that will polish out scratches and blemishes.
It takes some time rubbing the screen to work but it usually comes up a treat (dont press too hard) Iv recovered some absolutly trashed screen covers with it. Once its sorted use a screen protector to keep it good
Best of luck
Jun 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Polaroid FLM-2601 flat screen
It has a protective outer screen and depending on the depth of the scratch you might be able to restore it. You'll need to look on-line at a few aircraft site for a kit that is meant to polish scratches from the plexi in an aircraft windshield. There is a company in Oregon http://www.chiefaircraft.com/airsec/Aircraft/Windshields/ScratchRemoval.html
that sells the kit for 34.95....
It is time consuming but I have restored many this way!
Bill
Mar 27, 2008 | Polaroid FLM-2601 Television
Scratched tv screen
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper.
If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
Mar 18, 2006 | RCA P61927 61" Rear Projection Television
Nintendo DS Lite Console Logo
187 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
