Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Can i extend the life of the transfer unit Thank you
  • info5424 Oct 02, 2009
    Konica Minolta Biz Hub C250
    Thank you
  • benturley11 May 11, 2010
    which machine?
    Champion:
  • 214 Answers
You can reset it,use 63 or 80mA fuse, the fuse is located on the left side of tbu
Posted on Oct 15, 2009
Dell 3110 laserjet printer, belt unit close to life
This message is displayed when the pagecount of the transfer belt is 80,000 (ish)+.
The rated life of the transfer belt in the Dell 3110/3115 is 100,000 pages.
After that pagecount the transfer belt 'expires' and no further printing is possible until the transfer belt is replaced.
Feb 03, 2011 | Dell 3110cn Laser Printer
Drum end soon
  1. When you replace the drum unit with a new one, or just want to extend the life of your existing drum unit, you need to reset the drum counter by completing the following steps:
  2. Press the + or - button to choose "Machine Info".
  3. Press OK to proceed to the next menu level, and then press the + or - button to choose
    "Reset Parts Life".
  4. Press OK, and then press the + button to choose "Drum Unit".
  5. Press OK two times.
Good Luck and Thank You for using Fixya.
Jan 09, 2011 | Brother HL-4040CN Laser Printer
Imaging units for Bizhub C300
There is no setting you can extend the life, however, in the service mode ( utility->meter count-> stop, 0, 0, stop, 0, 1) then press stop, 0, c. There should be a setting in there that you can disable the "image unit life end stop" setting. You will get a message every 5 minutes telling you to change the unit, but your machine won't stop working. Otherwise you can just change the chip in the image unit.
Jul 26, 2010 | Konica Minolta bizhub C450P Laser Printer
E0067-0110
E067 High voltage-related error
0100 The measured current of the primary
transfer ATVC is abnormal twice in
succession.
Check on the primary transfer roller spring, Clean
the position where the primary transfer roller
contacts, Replace the primary transfer roller,
Replace the drum unit Check a value
of COPIER> DISPLAY> MISC> DRM-LIFE, and
replace the drum unit if the value is near 100
because the drum may have reached its life
expectancy.
0110 The measured voltage of the primary
succession.
Turn OFF and back ON the main power
Jun 07, 2010 | Canon iRC3100 Printer
The Phaser 7300 is being shut down because of a wrong signal that the transfer unit is at the end of its life. The transfer unit is a month old on a unit that has medium usage. It should not be at the end...
I think you might have a Spring missing for the Waste Toner Full Sensor. Truthfully, it is really hard to describe in a few sentences.
It belongs in the frame wall under near where you have the white waste toner section of the Transfer Belt. This spring pushes a flag up that hits the Paper Entrance Sensor (yes, near the bypass tray)
The PN for the spring is 116-2050-00
Whit
Item, Inc.
May 20, 2010 | Xerox Phaser 7300DN Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
Minolta c203 service menu
They extended the life of the image unit. They did not reduce the amount color in the print. Once they extended the life, the image unit will go until its copy qualilty will become completly destroyed. You will have to replace the image unit, sooner or later.
Mar 29, 2009 | Konica Minolta Office Equipment & Supplies
Transfer roller usage message on Phaser 7700. replaced..still wont print
I found the answer here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Resetting Transfer Roller Life
  • Resetting the transfer roller life is to be performed only if the Transfer Roller Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Transfer Roller or Replace Transfer Roller Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Transfer Roller is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Transfer Roller life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Transfer Roller life if the printer did not prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Transfer Roller Life.
  6. Press OK.
  7. Reset Transfer Roller NOW is displayed.
  8. Press OK to reset the transfer roller life.
Sep 30, 2008 | Xerox Phaser 7700 Laser Printer
Transfer belt unit is out of service life
Epson C-900. There is a fuse in the photoconductor unit and the transfer unit. The photoconductor has a shorter life, so it can be a few years before the transfer unit goes end of life. I suspect the fuses are blown by the machine when the counters get to end of life limit set by the manufacturer. On both components, if the fuse is reinstated/by-passed, the machine will think it has a new part. Spare fuses are available for the photoconductor unit.
The fuse on the transfer unit is a green resistor on a small board behind a black plastic dust cover on the front edge of the transfer unit (remove 3 screws to access). Ask a friend who understands basic electric circuits if you are stumped at this point.
Of course this mechanism is there to ensure you enjoy high quality output from your printer and keep it in top condition. By over-riding the mechanism quality will deteriorate and risk of failure increases.
KAF2008
Jul 29, 2008 | Epson AcuLaser C900 Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
195 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
