Question about SanDisk Sansa e250 MP3 Player
I cant get in my computer but its showing in device manager
Sansa mp3 player, i cannot the device in my computer but its showing in device manager..
  • 820 Answers
As you tell the device in can only be detected in the device manager.
It can not be seen as a removable disk in MSC mode and neither in MTP mode, showing as media player with the Sans icon.
Consult next page about 'player not being recognized':
http://kb.sandisk.com/app/answers/detail/a_id/42/kw/manager/r_id/101834
Refresh the drivers or manually ad the driver for the player as described.
Sansa manual for e200 series (version 2):
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
Important:
1. Check the system requirements of the computer as described in the manual on page 8 of the file [=page 5].
2. Charge the device using an USB connector directly to the computer,
not through a hub or card reader, preferred at the back side.
If more help is needed, just post a comment.
Posted on Sep 28, 2009
2 Suggested Answers
kishorechow
  • 74 Answers
SOURCE: sansa clip mp3 player
check drivers in xp or windows
do u have drivers cd ,
download drivers n install it.
ur's kishore chowdary +919441133420
Posted on May 18, 2008
Sansa Fuze, 8GB, unable to be turned on in the car after playing it just a short while ago, and is unable to connect to computer; screen is white.
You may need to now reset the player, that may have been a bit much for it. To reset your Sansa Mp3 player. Slide and hold the Power switch up for approximately 20 seconds. Release the Power switch. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present.
http://www.fixya.com/support/r3962743-sansa_mp3_player_frozen_reset_format
-Also try to refresh the driver in your PC. Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. >>>><<<Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
Wont do nothin
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 06, 2010 | SanDisk Sansa e260 MP3 Player
My MP3 player is frozen and it dosent show up on the computer?
Reset the player:
Then try this
<<<<< BUT TRY THIS FIRST >>>>>
Solve your MP3 Player Connection Problem.
Refresh the drivers
Feb 22, 2010 | SanDisk Sansa e250 MP3 Player
I'm having trouble charging my mp3 it won't stay connected how do i fix that?
Refresh the driver
Refresh the drivers
Feb 22, 2010 | SanDisk Sansa Clip MP3 Player
Sansa fuze 4g isn't recognized by computer...won't charge, screen only shows "writing" screen when body of mp3 player is pressed together...any ideas?
When i plug my Fuze in the pc, it turns on, but doesnt charge, and isnt even recongnized by my pc. So i cant put anything on it and it doesnt even show up in device manager.
Dec 26, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze 8mb format and firmware update
go into device manager in computer management and uninstall the sansa driver. Restart the computer and plug it in again
Jul 15, 2009 | SanDisk Sansa Fuze MP3 Player
Computer cant open sansa clip
Make sure the lock switch isn't engaged.
Double-click My Computer, and see if there is a Sansa icon (some computers will only show it as a removable drive or an MTP device).
If the computer is not recognizing the player:
disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Feb 28, 2009 | SanDisk Sansa Clip MP3 Player
Poblems putting music in my sansa
The problem you are having right now is because windows media player doesnt recognize your sansa..You need to make sure that your device mode is under MTP mode...To check that you need click on tools, menu, usb mode..and its going to show you the mode..select the appropriate one..Then make sure your computer has all the latest update from microsoft...check to see if your device is listed under device manager..if it is uninstall it and reinstall it..to check to see if the device is listed under device manager...click on start menu, right click on my computer, right click on properties, click on hardware and then device manager..sometimes it might have a yellow exclamations mark next to it..right click and uninsatll it and reinstall it..But make sure you have that device plug in on the back of your computer instead of the front..Let me know what happen before you rate me..
I hope that helps
Please rate accordingly
Thank you
COmputerrep
Mar 23, 2008 | SanDisk Sansa e250 MP3 Player
Problem with sansa e260 mp3 player
Seems like your windows doesnt recognize your device...In order to solve your problems please make sure you follow the steps below...I would recommend that if you dont windows media player 11 to upgrade to 11...Then go under device manager to see if your device is listed there..to get to the device manager..click on your start menu, right click on my computer and then clikc on properties, hardware and then device manager...device manager will show you all the devices that you have install on your computer....If the device is listed under disk drives uninstall it and then unplug the device and replug it back...Also you want to make sure that you have your device connected on the back of your computer..For further assistance please contact me...
I hope this helps..
Please rate accordingly.
Thank YOu
Computerrep
Mar 18, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk sansa m240 mp3 player
You can connect the device to your computer and manage it thru "My Computer. Open My Computer, then open the device (i.e. Sansa m240). Inside there is a Music folder, you can delete them from here. You can also drag songs here to transfer to the player. If you are not able to see the "music" folder, you may need to enable "Hidden Files and Folders" on your computer. Best of Luck.
Sep 06, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
116 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
