Question about Brother HL 1870N Laser Printer
I am trying to print an A0 size poster using 16 sheets of A4. I am using a pdf file on a mac. I need the printing to be without any physical margins. How is this done?
jaylex
  • 417 Answers
SOURCE: A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Posted on Feb 17, 2008
SOURCE: software issue - .pdf's not printing properly
We had the same problem. Ended up using the "print as image" option in Acrobat print dialog, then they came out OK.
Posted on Aug 15, 2008
SOURCE: Printing labels
You have to feed the labels through the manual feeder.
Posted on Oct 30, 2008
rey17
  • 66 Answers
SOURCE: Won't print InDesign documents or Adobe PDF files
hi,
try to download a new postscript driver and install it instead of using pcl driver!
Posted on Oct 31, 2008
SOURCE: cannot fill a3 sheet
Have you set up the page as A3? If so, should be ok if you set the printer paper size to A3. If you set up the page on A4 you will need to tell the the printer to 'scale to A3' and it's best to say you want to preview before printing
Posted on Mar 06, 2009
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
Does this model support printing on 34" paper?
The printer will support the following media sizes:
Roll paper (width) -
ISO: A3, A2, A1, A0,
JIS: B2, B1,
ARCH: 24", 36"
Others: 10", 14", 16", 17"
Cut sheet -
ISO: A4, A3, A3+, A2, A1, A0, B4, B3, B2, B1,
DIN: C4, C3, C2, C1, C0, JIS: B4, B3, B2, B1,
ANSI: 8.5 x 11", 8.5 x 14", 11 x 17", 13 x 19", 17 x 22", 22 x 34", 28 x 40", 34 x 44",
ARCH: 9 x 12", 12 x 18", 18 x 24", 24 x 36", 26 x 38", 27 x 39", 30 x 42", 36 x 48",
Photo: 20 x 24", 18 x 22", 14 x 17", 12 x 16", 10 x 12", 10 x 15", 8 x 10", 16 x 20" (US Photo size), Poster: 20 x 30", 30 x 40"
Dec 16, 2010 | Canon imagePROGRAF IPF720 Printer
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
Mar 22, 2010 | Adobe Acrobat 6.0 Professional for PC
The page prints to a small version in top left hand corner. everything is set to A4. Have tried all settings Have tried paper feed from back and front. Unable to get it to print a full size A4 page even...
Make sure on the Page Setup tab that the Page Layout says 'Normal-size' and not 'Poster' (poster tries to place four documents on a single printed sheet). If this is not the problem, try uninstalling and reinstalling the printer driver.
Feb 10, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Printing problem with Microsoft Office for Mac 2008.
have you clear the set print area? if not go to File menu, select Print Area then select Clear Print Area
try also to set your sheet into page view to find out if you can view right page of your sheet.
try also to check your margin.
Dec 14, 2008 | Microsoft Office 2008 for Mac: Mac
I can't print full bleed from CS3 to a Phaser 7750DN
You didn't mention paper size, so my apologies if you are using a sheet that will accommodate bleeds and just didn't mention it. This is the simple answer.
If you printing on 8.5 x 11 paper, you can't get a full bleed. You'll need to print on a larger paper size, like tabloid, and trim your 8.5 x 11 size out of that. There are no printers, even commercial offset printers, that can bleed an 8.5 x 11 design on an 8.5 x 11 sheet. There must be trim in order to get the bleed. it 'bleeds' off the edges of the design.
Nov 11, 2008 | Xerox Phaser 7750DN Laser Printer
I,ve done a cad drawing of a curved object and want to print it full size (i.e.scale of 1:1)so we can use it as a template.My printer is a canon IP4200 and does A4 pages. The full size item is 950mm X...
You should be able to do this using the "Poster Printing" option in the printer preferences. On the Page Setup tab, select Poster Printing as Printing Type, then click on the Specify... button. Select Divided into 16 (4 x 4) for the Image Divisions. This should give you enough area for the size you specified.
Apr 18, 2008 | Office Equipment & Supplies
Hi, I am using ms word 2007 and need an a3 sheet format. Its not in the page set up drop down menu and the only solution I have is to customise my page size. Even doing this however, and increasing my...
The print sizes available are dependent on the printers installed.
If you don't have an a3 printer installed on your computer, there won't be a A3 option in word.
if you install a standard pdf printer like cutePDF(simulates printer, but instead of printing document on paper, it generates an adobe pdf-file from the document) the option should become available in your dropdown.
Apr 04, 2008 | Computers & Internet
Printing an A3 document on an A4 printer
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
Brother HL 1870N Laser Printer Logo
53 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
