Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Dropped my hard drive and my computer is not able to read it
It also lights and hear it tries to read itself. But no luck.
Please help. Thanks
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
NB !
! ! DO NOT PLACE A HARD DRIVE IN A FREEZER ! !
THIS IS VERY OLD ADVICE FOR VERY OLD TYPES OF HARD DRIVES THAT ARE NO LONGER EVEN MADE. A FREEZER CAN CAUSE MORE DAMAGE.
If I keep collecting "frozen hard drives" at the rate i do i will soon have enough to build a small house.
Posted on Sep 28, 2009
  • 615 Answers
It’s hard to even try to do anything with it…the hard drive is made of very small parts and when gets hit it cannot be put back without opening it and that is impossible as it need to be in clean room…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Seagate backup plus srdospo
Either your driver for the hard drive has messed up or you need to exchange it for a new hard drive.
Usually just exchanging it causes less headaches and frustration than trying to fix it manually. It could also be that something is physically wrong with the drive, such as the arm inside the hard drive.
Good luck and hopefully that helps!
Jul 06, 2013 | Computers & Internet
Hp mini. The problem I stated is that the computer is not reading or acknowledging the hard drive. I checked resources online and I was told to remove the hard drive and then put it back in (unscrewin
There are three things that may be wrong with the hard drive:
1) connection was bent when you dropped it2) motherboard was damaged when you dropped it3) HD was damaged when you dropped it
Are there any bent pins (gold looking needles on connector)?Does anything "jingle" or sound loose when you shake the computer?When you plug the hard drive in and turn on the laptop, can you hear it spinning?
If you cannot hear the hard drive spinning and the laptop is plugged in then I suspect the hard drive is bad.
Nov 16, 2012 | Computers & Internet
I dropped my drive and now the computer won't recognize it. The blue light is on with the red light. Help!
Sorry to hear that your drive is having trouble. When you start the drive, do you hear it turning?
Is this a external that you can remove the hard drive? You may try to power down the external, power it back up and shut down your computer. The conect the external and turn the computer on.
Let me know if you can hear the driver turning and it you can connect after going thru the process above.
Brian
Feb 05, 2011 | SimpleTech Signature Mini 320GB External...
I dropped it and now it is not listed in my computer area. I have limited computer expertise
This problem was posted under a heading for an internal hard drive. If this is what you have and dropped, your drive may be a goner. Hard drives don't take kindly to being dropped. They're a mechanical device with close tolerances, and enough of a shock can damage them so they no longer spin or read. Shock can also crack the circuit board or break components loose so the drive stops working electronically even if it's mechanically okay.
On the other hand, if this is an external drive in a case, there may be hope. The drive itself may still be bad, but you might simply have knocked an internal connection loose. In external drives, there is an interface board containing some power circuitry, the external power jack if one is used, and connectors which plug into the drive inside. The board may have been damaged or the connections knocked loose, while the drive survived. The only way to know for sure is to open the case and remove the drive, then connect it into another computer for testing. On some cases this is fairly easy, while on others it's like breaking into a bank vault. You can find disassembly instructions for most brands and models on the Internet.
I hope yours works out. Good luck and thanks for using Fixya!
Dec 28, 2010 | Western Digital WD Scorpio Blue WD2500BEVT...
Dropped it want read
First off....most people don't like to answer these posts because nobody wants to hear that the drive is most lilely broken and the data lost...the fact is, these external hard drives or any hard drive for that matter are not built to be dropped unless they are built to military specifications.....now with that said, there is the possiblitiy that only the interface between the external case and the hard drive itself has been damaged. There is a small plastic circuit board inside the enclosure that houses the SATA connection of the hard drive with the USB connection of the enclosure. This interface allows the hard drive to communicate externally with any computer. These little circuit boards are very fragile and are usually the first things to go when something bad happens. The drives themselves are fragile but not as much as the interface. What I would suggest is that if you need to get to your data....disassemble the enclosure and buy a SATA to USB hard drive adapter at a computer retail store and attach the removed drive to the adapter and plug it into a usb port on the computer. The computer will then power the drive through the usb port and if all goes well will recognize the drive and display the drive under the "My Computer" icon. You can then access your files. To disassemble the My Book, look for a small circle on the side of the case, on one side is a sticker that covers an attachment screw. Remove the screw and then on either end are catchment teeeth that have to be disengaged from the mounting try inside the enclosure. The outside of the enclosure slides open from the rest.
May 24, 2010 | Western Digital My Book Home Edition 500...
I dropped my hardrive and now it beaps and is not recognized.
sometimes even the slightest bump will offset the heads. Difficult to fix and guarantee that the data will be preserved.
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Iomega (33222) 80 GB Hard Drive
Dropped my wd portable hard disk now computer is not reading it
brother
your hard drive has either a crashed head,ir amisalligned head due to dropping it several times. also head stuck to platter is the result of dropping it.and may be the motor of the hard drive has lost its central axis and has got jammed.
if your drive is still spinning i am sure it has head crash problem only.
please try to either get it replaced if its under warrenty.
if you wish to recover data , please pm me.
datarecoveryfactory
Sep 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dropped firelite: still spins but is not recognized
Ok same situation happened to me i dropped my Firelite 80Gig, drive would spin no light and the computer would not recognize the drive. All I did was open the case an saw the the internal hardrive had come loose from its pin connection. So all i did was pushed it back in and BAM now it works, hope this helps other people. Thanks C.J.
Mar 20, 2008 | SmartDisk FireLite 40 GB Hard Drive
Slightly dropped seagate external hard drive, recover data??
Will the drive be shown under "Disk Management"? If no, make it. Then the MOST effective way is to try some so-called data recovery software to rescue the data.
First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem!
Remember - Always make Backups of your precious data!
Mar 16, 2008 | Computers & Internet
Disk read error, please help
If it was dropped on the floor, more than likely, that spinning hard drive is damaged and has failed. The computer caqnnot load the operating system. You will definitely have to replace the hard drive, and hope the data is recoverable. Keep in the mind, the hard drive is constantly spinning, and any shock at 30G's or more can be fatal.
Picture moving a turntable while its playing, accept, instead of spinning at 33.3 rpm's its spinning at 5400 rpms, faster than most car engines......
Good luck.
Dec 16, 2007 | IBM ThinkPad T43 Notebook
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
112 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
