Question about JVC KSAX4504 MOSFET 600-Watt Amplifiers Amplifiers
Amp keeps blowing the fuses
Every time i try and hook up my amp to the car i make sure nothing is connected b4 i put the wires on once i done this i hook the wires up and the battery wire shorts and sparks and blows the 2 25 watt fuses. Can u help.
  • 52 Answers
Serious short circuit on your output transistors, need replacing.
Posted on Sep 28, 2009
Testimonial: "thanks that worked great"
My 2008 suzuki grand vitara keeps blowing the fuses for the ACC outlets. both are 15AMP, but even with nothing plugged in, nothing down in the outlets and even with larger AMP fuses, they keep blowin
If you use too large a fuse, the wiring can catch on fire, and the whole car could burn up. You'll need an auto electrician to trace that problem. You can remove any bulb and unplug any device that is on the Acc(essories?) circuit; then see if a fuse will stay; start replacing items till you blow the fuse. It seems like a dead short which can surely melt wires if you keep taking chances. good luck.
Feb 14, 2015 | 2008 Suzuki Grand Vitara
I have a 2005 cavilier..it keeps blowing the main 30amp fuse when the ac is turned on..any help
you need to inspect all AC WIRING, to find the SHORT, thats causing the fuse to blow ! donot put another fuse in until you locate the shorted condition, ( bad connection, frayed wire, bare wire touching metal along this circuit, you might have a bad switch, your ac has two switches under hood, one @ high pressure side and one @ low pressure side. and your main control switch, check all wires & connections
Mar 11, 2013 | 1991 Chevrolet Cavalier
95 ford mustang starter fuse keeps blowing. what should i do?
have you checked that the starter itself has not been grounded out (short in the wiring?)
The chances are this is what is causing your problem, start at the starter motor & follow the wires, check every single one, if you have a bare section that comes in contact with the body or anything else metal it will ground out that wire & cause the fuse to blow every single time even if you were to double the fuse resistance I.E. if the fuse is a 20 & you put in a 40 it will still blow - that last part is ill advice - never put a higher amperage fuse in a socket that was intended for a lower amperage fuse - it could cause a fire & serious injury, check all your wiring from the starter you have a short in the system somewhere it's just a pain in the a
4rse locating it
Sep 21, 2012 | 1995 Ford Mustang
Tail light fuse keeps blowing
91 honda accord lx, fuse keeps blowing for tail lights. changed rear bulb sockets but still, same problem. fuse blows soon as i turn on the park lights. what can be the problem?
Mar 20, 2009 | 1994 Honda Accord
Wiring installation on Majestic amplifier total 60watts 2x30 model# ma-60
To install the amp you need a amp wiring kit they range from $15 and up depends on how many watts u have.Once you have the wiring kit start with the ground wire it needs to be no longer then 24 inches long the shorter the better find a good ground in the trunk or where ever you want to install the amp make sure its metal to metal no plastic paint or any other debrie is in the way of the metal.If you can't find a paint free surface all you will need to do to fix this is sand off some of the paint and then ground the amp.The ground wire needs to be connected to the amp before any other wire once you have the ground connected then connect the battary wire make sure you have the right size inline fuse on the battary wire that also depends on the watts of the amp.once you have those 2 wires connected then u will need to pull the stereo out of the dash and hook up the remote wire to the power antanna wire if you have a factory car stereo and don't have a power antanna you can try one of these solutions 1st one Run the remote wire from the battary wire on the amp and use a toggle switch between the remote and battary wire or you can run the remote wire from the amp to the fuse box of the car and hook it up to a fuse that only works when the key is turned on.Once you have all this hooked up its time to hook up the subs/speakers on the amp it should indicate if its bridgable it will show lines from one positive and one negative and at the top of the lines it will say bridge but if not the just connect the speakers positive to positve and negative to negative.If it is a bridgeable amp i would only recommend hooking it up bridged if you are hook up subs if you are using 6x9's on the amp you don't need to bridge the amp.If u have any more ?'s just ask i can help with this i've done this alot.
Sep 03, 2008 | Car Audio & Video
Hifonics amp keeps blowing the main fuse
have u tried using thicker wire from the battery to the amp u need to put a fuse in there thats a minumum 60
Jul 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Blowing fuses
Here are some answers:
1. Make sure your amp does not have a higher amp rating then the fuse, For example, an 18 amp amplifier will blow an 15 amp fuse, so connect it to a 20 amp fuse
2. you have a connection issue, where something is shorting out
3. you are pushing the amp or car to it's limit with how loud you put it, and thus blowing it, fixed by getting a more powerful amp and a better fuse.
4. or there is something very wrong and cannot help you and you would have to bring it into a shop.
Nov 18, 2007 | Car Audio & Video
Lanzar amp
If it keeps blowing fuses then #1 its internally damaged or "blown" .. Or #2 i would make sure you have the battery power hooked up to the + terminal and the ground wire running from the car body to the - terminal.. so if its hooked up correctly and keeps blowing fuses then it requires repair.. I wish i had better news but thats all it can be...
Aug 20, 2007 | Scosche Industries Scosche High...
JVC KSAX4504 MOSFET 600-Watt Amplifiers Amplifiers Logo
175 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
