Hi. I am considering buying an RZ67. It is in good shape, but has a cracked mirror. What is the cost for shipping and repair/replacement of the mirror (and recalibration?) from Northern California (Eureka, postal zip 95501)? Thanks.
SOURCE: Mamiya RZ67 Camera Older model.
Problem solved- The camera does not operate correctly unless the battery is in good condition, in place, and all the contacts are clean. In the RZ76 as opposed to the old RB models the components "talk" to each other: via electronic circuits. The back "tells" the camera bod if the dark slide ins in or out and whether the film is loaded or at the end of the roll. If the batter voltage is too low or the contacts are no clean and making full contact the body has no way of knowing the condition of the film backs and the interlocking mechanisms fail to work.
What I did was firstly test the battery under load and discovered that the cell was a bit low. It was a fresh battery but it is a good idea to turn the camera off after shooting in case the is a slight current draw when the camera is idle (?) . I replaced the battery and traced the voltages through the body to see if it was getting to some of the contacts such as the onces on the meter prism which has LEDs to be lighted. I also used an ohm meter to check out continuity- everything seemed to be in order. I then cleaned all the contacts including the battery terminals withl alcohol and made sure everything was dry and clean.
Now- everything works. The camera was turned off overnight and the battery has lost no voltage when tested under load..
This camera is equipped with RB lenses which have no electrical contacts and therefore the camera and lenses can't "communicate" so the meter will not work with theses older lenses.
Ed
SOURCE: TR2200 bread pan, part number 22399. How much?
use oilve oil and reset the seal also you can use peanut oil it has a high heat range or wok oil also
SOURCE: MIRROR INDICATOR BULB
You cannot change the bulb - the indicator is a sealed unit - mine failed because water got into a crack. VW will sell you the unit - you need to dismantle the wing mirror to fit it - took me about 20 mins. Cost of the unit was about £17
SOURCE: need replacement blades
You can buy parts here. You might be able to get some at sears parts center.
http://www.abtecparts.com/psilex_702.htm
Good Luck and Please Rate FixYa!
SOURCE: 2007 Hyundai Accent Hatchback cracked side mirror glass
hi from uk answer is yes the mirror glass can be bought on its own at least here in the uk HALFORDS do a selection of these for various models also a mirror glass that simply sticks to the cracked glass full surface by a backing of double sided glued cushion pad so assume your location will have these at motor supermart ? if not then you can do as i have done in past ? make a card template of mirror then cut or have cut ? your own mirror then double sided tape will do the same job?
