Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Printer not work
Sir since last 10 hours i will try to repair my canon mp730 but this is not functioning and indicating the error code ##334.so could tell me what is the minning of this code. i m very thanks ful to u.
your's s v jani
My printer will print on every type of paper i set it to in the preferences, except "plain paper". the machine also doesn't copy when set to plain paper also. I printed a report cover on matte paper which printed fine, but when i change back to plain paper, it doesn't print.
Posted on Jan 03, 2008
How do I fix error code E000001
sir
do the error clear in service mode.
COPIER-FUNCTION-CLEAR-ERR.
Thanks
Dec 21, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Error ##334., its my problem
The error code ##334 represents a EEPROM check error. The manual says this means the Printed Circuit Board may need replacing, however, try this procedure.
Insert paper into machine.
1)To enter service mode press Menu, copy, #
2) Select Test Mode with the + or - keys
3) Press OK
4) Press 8, lcd shows 'Please Wait', after wait, press 3, the lcd then alternates between 3-0 (EEPROM clear), and 3-1 (Purge flag)
5) When EEPROM clear (3-0) shows in lcd, press 0, then OK, then Stop then press the OFF button.
Repeat the above from Step1 to step3
in step 4 this time reset the Purge flag by pressing 0 when 3-1 shows in the lcd, OK, Stop, Off.
If the red fault light is still blinking press Resume.
hope this helps
Sep 05, 2011 | Canon SmartBase MP730 All-In-One InkJet...
Connon mp730error ##334
#334 is an eprom error and if turning on and off does not reset it, you have something going on with the main logic board.
http://printer1.blogspot.com/2009/01/canon-multipass-mp730-service-manual.html
Above is a service and repair manual this will assist you to troubleshoot and hopefully repair, although I fear with this type of fault, it needs to be returned to the factory.
May 15, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
I have a Canon MulitPass MP730. Wrong Cartridge message.
It's worth repairing, That error on a Canon is saying that the printhead is bad, not your cartridges. The part number for your printhead is stamped on the side of the printhead could be QY6-0049-000 but I'm not sure.
Jan 10, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Canon pixma pm500, error code 5200. inocrrect rpint head/ did corrective measures as per canoin usa website (remove ink cardtidges, remove then put back print head etc...still rec error code 5200.
Issue: ERROR LCD: Error Code 5200
Solution: Press ON/OFF switch and wait a few minutes before powering back on the device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear an error, power off the printer and power it back on. Before powering back on the printer, wait five to ten minutes.
  1. On the operator panel, press the <ON/OFF> button. (The display will go blank.)
    Note: On rare occasions, it may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately five to ten minutes and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
  4. Issue: ERROR LCD: Error Code 5200
    Solution: The MP500 may require repair
    Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.Find a Service Location
    If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
    • Obtain Support by Email
    • For toll-free technical support*, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. Eastern Time, excluding holidays).
Aug 20, 2009 | Canon Pixma MP500 All-In-One InkJet...
Printer
#334 is an eprom error, try turning it on and off to reset it, if it doesn't work there might be a problem with the main logic board.
Apr 12, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Canon smartbase mp730
Have you tried doing some maintenance like nozzle check,printing head alignment,clean the nozzles if not then try it by going into control panel - printers and faxes - where you see your mp730 right click and go to properties then click on the last tab which would be maintenance.Try those options if none worked then u might have to replace you print head and that should work
Nov 26, 2007 | Canon SmartBase MP730 All-In-One InkJet...
Canon MP730
If you haven't yet, try a cable that is bi-directional.  They are available in any electronic store.
Sep 18, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
166 people viewed this question
Clive
Clive
old marine
old marine
