Question about Dell E173FP 17" LCD Monitor
There screen will not switch on and the power light is flashing
This was the same symptom on a Dell 19" LCD monitor I got and after disassembling it found a
shorted transient absorber diode (ZD15) on the power supply board. This diode is a protection diode between the 5V and 12V output. You do not need it
to be in the board but if you want to keep the same
protection on the board I suggest you order a
replacement from Digikey.com or Mouser.com.
You will need to know how to separate the front bezel from the rear casing to get to the power supply board. I have a picture of the power supply board and the bad part is at the bottom left of the board with the designator ZD15.
Posted on Oct 18, 2009
Samsung digimax v800
The manual does not indicate what is wrong, when the green light is flashing, other than the flash is charging.
It could be the flash can't be charged, because the flash capacitor is defect, or the battery does not have enough power.
Try switching on the camera while not in automatic mode (M of so) or when in video mode. If the light on the main dial still flashes, I think you should look for another battery. But first try another battery, before you buy one. (Or test the camera with an external power supply. Don't forget to switch of the camera, every time you change the power supply.
Mar 14, 2014 | Cameras
I have a 26mf231 Magnavox 26 inch tv. The screen on the tv just flashes over and over. Never powers up. I took out the power board and all the capacitors look good. Thanks in advance
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 30, 2013 | Philips 26MF231D 26 in. LCD Television
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a message to power on and off again. I\'ve tried switching on and off a few times, removing battery pack and memory card, but nothing seems to be solving the problem.
Feb 19, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Power led lights green, touch screen flashes white and powers off
try taking it apart again and checking closely to see if any inner cable is loose,
Apr 13, 2010 | Nintendo DS Lite Console
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Power button just flashes will no turn off AND nothing on the screen
On back of the computer is a on off switch for the power supply, or unplug the computer for one minute. Turn the switch back on, or plug the computer back in and try to turn it on.
Apr 20, 2009 | Computers & Internet
Dell E173FP 17" LCD Monitor Logo
276 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
