Question about Ovens
Hi. How do i remove the light cover in my Stoves Prelude oven? Probably very straightforward but I don't want to force it!
  • 142 Answers
Cover either just pulls off if flat type on sides of oven wall or domed type unscrews anticlockwise.........
Posted on Sep 28, 2009
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
How can I clean the roof of my Stoves 720EF Electric Double Oven
I have been using the Lakeland brush on oven cleaner for ALL of the inside of the oven including the stay clean bits without any problems. With the 720, I just brush on the cleaner and follow the instructions. To answer you question, I don't actually lie upside down, you should be able to reach it fairly easily. You may need a number of attempts to get the worse of! Be careful of the thermostat sensor at the top rear right of the oven. It should be bright and clean but will not take any heavy handed cleaning, especially the thin wire leading to/from it. FYI the fan cover at the rear of the oven is held on by 4 self tapping screw and comes off/ goes back on with any problems.(The rear of the cover by the vents build up with grease). Don't use the cleaner on any aluminuim bits ( which includes the fan) as it harms it.
Dec 31, 2011 | Stoves 720EF Electric Double Oven
The glass panel behind the control knobs has shattered can I replace this model is stoves 720ef
The best bet is STOVES for a replacement - if they have one. It is relatively straightforward to replace. With all the buttons and knobs removed, there should be two screws underneath the panel , i.e. pointing upwards at either end of the panel,. The panel will also have two lugs along the top edge that locate into the top off the oven. The panels lugs should be first located into the oven before the screws are inserted. It may be a bit of a struggle but can be done.
Sep 11, 2011 | Stoves 720EF Electric Double Oven
Where can i buy new bulbs for the lower section of my oven???
Any good electrical retailer should have oven lamps. They need to be "oven lamps" because of the heat. You may wish to take one out to check its size and rating before you buy. All four lamps in the oven are the same. To get them out, you will need to remove the glass cover. To do this you should see a little lip on the edge of the cover facing you from the front of the oven. Insert a blunt screwdriver or something similar and twist it, that should be all the force that is required. If there is oven grease around the cover it may take a little more effort. There are cut outs on the glass to allow for the bulb. ALSO, don't attempt to do it if the oven has been used because the covers get very hot. When the oven is cold, briefly turn the switch to the first position to put the lights on, without the heating fan. Have a look to see what to do and you should be OK.
Sep 05, 2011 | Stoves 720EF Electric Double Oven
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Jun 22, 2011 | Stoves Ovens
I need to remove glass light cover on stoves oven model 444445115 without breaking it to change the bulb
hi hold it with a damp cloth and turn ..if it dont unscrew u need to change the unit as a whole :( they end up breaking .
Feb 27, 2011 | Ovens
Hi I have a stoves 720EF oven and grill, and the light bulbs need replacing. the instructions are not clear enough! It says to grasp the back edge of the light cover and move forward. There aren't any...
As you have found out the covers are made of glass and can get very hot, so don't attempt this if the oven has been on for even a little while. You may not have noticed it but in the centre of the edge of the glass cover facing you when you look in the oven, there is a small recess in the glass adjacent to the oven wall. It is probably covered up by grease etc. It is in the centre about 1cm long and about 3mm deep. You will need a screwdriver ( an old blunt one is best so there is no sharp edges) that just fits into the recess length wise and then twist it. This should start to prise the cover away from the oven wall and then you can get your fingers behind it to pull it away. Note the cut out on the edge of the glas when refitting. This is to allow for the lamp holder. When you put it back, as long as the recess is towards the font of the oven, you should be ok.
Jan 02, 2011 | Stoves 720EF Electric Double Oven
Hi there i have a stoves newhome double oven the bottom oven has suddenly stopped getting hot the fan and light are still working but we have no heat.we have tried changing the thermostat but that has not...
If the fan is working o/k, then I would suggest that bthe oven fan elementt has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Dec 28, 2010 | Stoves Ovens
Prelude df1100a stove
My email is andybart84@gmail.com Please send me the complete manual df1100 prelude stoves. Many thanks
Oct 17, 2008 | Stoves Ovens
Ovens
if the oven fan and light are not working, then the clock probably needs setting. if oven fan and light work, but no heat, then the problem is probably the circular element round the fan. remove the back panel of the oven and you can often (but not always) see the damage. replacement of the element is straightforward
May 06, 2007 | Zanussi ZBF660 Electric Single Oven
Ovens Logo
71 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
