Question about Jenn-Air JMC7000 Microwave Oven
No power on Jenn-Air JMC 7000 ADB Microwave
Still looking for solution. Jenn-Air JMC7000 ADB Microwave. No power, no clock, no nothing although regular oven combo still works. Is there A fuse or a reset of sorts? Will buy new if it can't be fixed but would like to fix it first.
  • 2nd Owner May 02, 2008
    Jenn-Air JMC7000 ADB Microwave. No power, no clock, no light. The oven below still works. The repair person was out and changed the fuse. Seemed to fix the problem...temporarily a couple of weeks. The fuse blew again (after cycle completed). The second repair person checked the AMPs while operating and it was pulling 12.3 amps.
    Latest episode: Ran the microwave for 3 min to reheat. Cycle completed w/ beeps. Wanted to reheat a second item...no power, no clock, no light.
    Any suggestions on what is causing the fuse to blow?
    Problem Solver:
  • 5 Answers
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Posted on Jan 04, 2008
This advice was right on. I must have an newer model of the microwave because when I removed the front frame (4 screws) I could easily reach the breaker switch. It was on the right side and I could reach it with my hand. Once I pressed the button the microwave came on. I can't remember anything like this being this easy. Now I have to figure out how to fix the glass panel on the front of the oven door.
Posted on Jun 06, 2008
I have the same problem every time I use the oven for a long time and then use the micro.
Solution is simple, yet unbelieveable.
This is a toggle switch. It is located on TOP of the oven box.
It is almost impossible to reach...but once reached, all you have to do is push it and it resets the micro.
1-remove the "frame" around the micro.
2-pull the micro out (use 2 people) far enough so that you can reach your hand - or I use a wooden yardstick- to toggle the thing. It is VERY tiny.
Posted on Mar 24, 2008
  • 833 Answers
Xxx, there is a chance that this is on a separate breaker. Find out by plugging a lamp into the outlet and see if you have power. No...reset your breaker. Yes, take the front key panel off the unit. Locate any fuse inside. Test it with a multitester if in doubt. Also, test the thermo sensor....black, diameter of a dime, 3/8 inch thick with two wires coming out. It should be continuous. Usually, it is located on the oven wall in the keypad area. You can short the wires to test...with a paper clip...taped up...Never run without this sensor.
Posted on Dec 19, 2007
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: No power on Jenn-Air JMC 7000 ADB Microwave
It's either the fuse or the thermostat on the magnetron.
You can download the service manual here.
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 02, 2008
My microwave stopped working suddenly. The front pannel is not working and even its clock is off.
I would suspect the fuse first, then the magnetron's thermostat second.
The full service manual for the JMC7000 is here.
You can order parts from the Pros here.
Dec 27, 2012 | Jenn-Air JMC7000 Microwave Oven
Looking for an exact size replacement for Jenn Air JMC7000
it looks like the Magic Chef MCD1611 is the same size
Jun 16, 2011 | Jenn-Air JMC7000 Microwave Oven
JMC7000 No turntable, interior light or microwave function. Just the clock, timer and keypad functions...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 24, 2010 | Jenn-Air JMC7000 Microwave Oven
No power in the microwave. It is as if you unplugged it. Is there an internal fuse in the unit? There is power to the unit. The unit shows nothing on the panel and when you open the door, no light comes...
If you look at the back of the oven there are usually small fuses or breakers back there. Check to see if that is the issue. Also if you haven't already make sure the wall outlet is functional.
Dec 14, 2009 | Jenn-Air JMC7000 Microwave Oven
JMC 8100ADB
Check the capacitor with an ohmmeter, if the meter reads 0 ohms the capacitor is bad and needs to be replaced. More likely, though, the magnetron is bad.
Sep 23, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
Dec 19, 2008 | Jenn-Air JMC7000 Microwave Oven
prototech@usa.net
Apr 29, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Jenn-air microwave JMC 7000 ADB has no power
Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
808 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
