Question about Canon ImageClass MF5770 Laser Copier Printer Fax Scanner Network
All printing is too light, even when I set the exposure to the darkest setting. Can I make an other adjustment?
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
Can you please advise what video recording settings to use on my AG HMC 40PJU so that the videocamera will automatically adjust the light exposure entering the camera? I video a lot of stage plays and...
At the theatre prior to the performance, ask the lighting director to show you one of the brighter performance stage light configurations and allow you to set the camera's white-balance. (It's easier to deal with a little under-exposure in post production, than it is for over-exposure.) Then adjust the exposure accordingly during the performance.
Preparation/Planning: Either at home or in the theatre, if you practice setting the white balance and then adjusting the exposure for varying levels of light, with your camera connected to a video monitor, so you will see it more clearly in real time, it will help adjustments during filming the performance more fluid.
Also consider using a lens filter. Practice various combinations to see what suits different light levels and gels for best effects. When possible, if using a stand alone camera (not cabled into a control room set-up) I prefer using a video monitor for each camera person to give better ability to manage adjustments of camera settings as needed.
May 16, 2011 | Panasonic AG-HMC40 Camcorder
My copies come out way too light but when printing from computer prints fine. do i need to change out something that is specific to copying rather than in the actual printing of things? Thanks for any...
That not a problem, that OK
some of the printer low quality is working like that as you have not specify your printer brand name and model name that all i can answer it
Mar 19, 2011 | Office Equipment & Supplies
Changed the ribbon, but the labels are to light.
The DARKNESS setting controls the amount of ink released to the label. The 105 has a range of 1-30, 1 is the lightest - 30 is the darkest. The setting used will depend on the combination of label / ribbon used. There is no "correct" number, always try to use the lowest setting with acceptable print quality.
The DARKNESS can be adjusted from the front panel by pressing SETUP and changing or DARKNESS can be controlled from the software or printer driver. The printer driver or software usually overrides the setting in the printer.
Hope that helps !
May 07, 2010 | Zebra 105SL Thermal Label Printer
I have a Sharp AL 1642 CS. It prints black copies. It came out of no where so I know it isnt dust on the lens. Even after adjusting brightness settings it prints pitch black pages. The bulb on the scanner...
Problem on three things.
1.OPC drum cleaning blade is very old,so lost her activities.
2. Laser unite very dirty,so you need clean.
3. setup or configure exposure control.
# Press Auto key three second
when exposure light indicate now position,select way lighter side.
Jan 20, 2010 | Sharp AL-1642CS Copier
Printer prints very light
its may be happend due to the Dust in the LSU unit.
remove the LSU from machine and open. Then after clean all the mirrors and polygon .
after that your problem should be solved.
Mar 03, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
26 people viewed this question
old marine
old marine
