Hi i am looking for a manual/ userguide for a
Hi i am looking for a manual/ userguide for a Firenzi Autowash 1200 -Model number SWD1210.
Can you help?
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: My firenzi autowash 1000 won't spin
see this causes and fix it. God bless you
Belt
The belt may have come off or broke. If you hear the motor running but nothings moving the problem is likely the belt. This is easy and to check and replace.
Door Switch
This can cause the washer to not agitate or go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Posted on Oct 17, 2012
I need a manual for a firenzi oven fsf650
Request the manual directly from Firenzi.
Jan 12, 2015 | Grilling
Belt
Door Switch
Oct 16, 2012 | Washing Machines
I need an instruction manual or booklet
I could not find a model 12005 but I did find a 1200. You'll find several different manuals for Spot Bots at the link below. There should not be any significant differences among the Spot Bot models.
http://www.bissell.com/searchresults.aspx?searchtext=1200&mode=userguides
May 18, 2010 | Bissell 12005 Spot Bot Handheld Vacuum
Looking for a manual to help me use EasyCapt Vidoe capture USB2.0
hi biffobonzo, you can go to this site:
http://consumersupport.lenovo.com/us/en/UserGuide/Guide.html
select the brand and the model, then the user guide includes the easy capture manual...
May 09, 2010 | Acer Computers & Internet
No manual
mnmpie, go to http://www.bissell.com/images/UserGuides/1200_805.pdf
Thanks.
Nov 15, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
