Question about Razer RZ01050300 Mouse
Razer wireless mouse wont work in PC mode on mac
I cannot run my wireless mouse when i switch to windows on my mac
  • 29 Answers
I think you are using a Non- Windows specified Driver. If yes then you will have this problem. Try a Windows Driver ( the Windows which you have ). Also if it doesn't solve, check that is the Program is running in the compatibility mode of your windows.
Thank you, Have a nice day.
Posted on Sep 28, 2009
Orochi razer wont move or click
make sure the drivers are up to date. you can find them on the manufacturers website
Jul 17, 2013 | Razer RZ01050300 Mouse
Mine is Razer Lachesis Mouse can't be detected anywhere, but the blue light is on, I don't know whether it's a software or a hardware problem..
This can be a complex problem, First try plugging the mouse into a different computer to see if the problem is only with the current computer. After that try going to Razers website and downloading device drivers for windows (or mac). Hopefully that will allow your computer to detect the mouse. Also make sure that the laser for the mouse is working (it may be hard to see on performance mouses, but look carefully for a red dot).
Mar 14, 2011 | Razer RZ01050300 Mouse
Can the targus bluetooth presenter for mac be used on a windows system?
Sorry it can't be used on win because there are no drivers for it.
Jun 13, 2010 | Targus Bluetooth Presenter for Mac
Razer Deathadder crashes computer
I think that cable of your razer is broken and some cables are shortcircuited, don't plug it in computer, you could ruin your motherboard. If you want your mouse working and have some technical skills, buy some usb cable with same plug as mouse have and replace it
Jul 10, 2009 | Razer DeathAdder RZ01-00150100-R2M1
Kensington wireless mouse doesn't work on Mac laptop.
Kensington wireless mouse is compatible with this system:
PC-Windows® 98, Me, 2000, or XP with USB port
USB Macintosh® with OS 10.1.5 or later
USB Macintosh® with OS 8 and 9 device will only function as a 1-button mouse
If you buy this item you have a disk utility on it and provide the software to run on the system. If not you can download it at this site: http://us.kensington.com/html/4398.html
Jul 08, 2009 | Kensington PocketMouse 72214
Razer Mamba Problem
I had this same issue when the software hung. I thought my mouse was dead(no lights, no response when plugged in on my Vista machine). The way I solved it was to goto my XP machine(this may work in Vista 32bit too but I have 64bit and didn't wanna chance it) and install the firmware update software.
After installing the software, run it and get to the screen that tells you to hold down the pairing button when connecting the mouse. Then make SURE your mouse is turned OFF via the ON/OFF switch on the bottom, then HOLD the pairing button on the bottom of the mouse and connect the USB cable. When you do this, you should see a note that XP sees a bootloader and it will want to install a driver for it. Let XP install automatically. When it is done installing the driver, click next on the software screen and it should say it sees the mouse and the UPDATE button should be green. Click it and it will update. This should work, even if it looks like your mouse is dead(no lights when plugged in and not being recognized properly).
The key parts are make sure the mouse is OFF(vai the switch on the bottom) before starting and also make sure you hold the pairing button down when connecting the USB cable. If your system doesn't see a bootloader when you connect the mouse, the update won't work properly.
Jun 21, 2009 | Computers & Internet
Razer Lachesis dont turn on after reboot???
YOUR USB ROOT HUB MAY BE IN HIBERNATION. GO TO DEVICE MANAGER IN CONTROL PANEL AND RIGHT CLICK ON EACH USB ROOT HUB ....GO TO PROPERTIES AND UNCHECK ENERGY SAVING MODE.....ALSO CHECK POWER OPTIONS IN CONTROL PANEL AND UNCHECK HIBERNATION OPTION.....THIS SORTED OUT MY RAZER LACHESIS THAT WAS NOT BEING PICKED UP BY WINDOWS..
Dec 18, 2008 | Razer RZ01050300 Mouse
Razer Copperhead mouse problem
Check the BIOS settings on your computer: is it set to boot from USB drive?  that may be the problem.
Mar 28, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Razer copperhead problem
I have something like you've all described with mine occasionally, normally, turning the mouse over and rubbing the laser surround with my finger vigorously is enough to clean off the crud that seems to be causing the problem..
I've never had any software problems or anything with mine..
Feb 18, 2008 | Razer RZ01050300 Mouse
Hotkey mode
This just worked for me. Using your PC keyboard, boot up to the PC first and then power up your mac. Hit the scroll lock twice and IMMEDIATELY hit enter. You have to go fast- click-click-click with no hesitation and it works great. I still can't toggle the hot keys to set up my mac keyboard, which I prefer using, but I'm assuming it takes the "right" timing on the keys. I'll keep trying.
Oct 23, 2007 | IOGear GCS632U 2-port KVM Switch
Razer RZ01050300 Mouse Logo
70 people viewed this question
Top Razer Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Avishek Samaddar
Avishek Samaddar
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
