Question about Brother Sewing Machines
I've got a brother RS-36 and have just got it out after not having used it for a while. When I depress the pedal the neddle moves up and down as you would expect but the machine does not draw the fabric through - it sews in the same place and then jams - what am I doing wrong?
  • 73 Answers
You should check whether claw is pulled down ad it has two position. Moreover some machines have switch which lower pulling mechanizm thus it doesnt pull fabric
Posted on Sep 28, 2009
My brother rs-36 wont pick up yhr boobin thread please can you help
Try installing a brand new needle. Verify the needle is installed with the flat part facing the correct direction.
If has no positive affect, then it's possible the timing is off on your machine. Search for sewing machine timing or take it for service.
Apr 21, 2017 | Brother Sewing Machines
The foot control on my husqvarna 545 viking sewing machine quit working. What's going on?
First not familiar with exact product , however troubleshooting is common.
This is if pedal can be unplugged and you have access to volt meter (these are cheap enough under $20 and have other uses to support purchase) , set meter to measure continuity, set meter to lowest ohms to start. Before using on pedal touch the red and black leads together, touching the result should be zero on meter, not touching infinity or blank. Connect leads in various manners to the pins or sockets move pedal. If your meter reads a high number while moving pedal you have an open circuit.
If you see the meter fluctuate as you depress pedal that would be expected ( normal) but then when fully depressed go high ( open) your pedal switch is faulty. The variation in resistance as you push pedal slowly is what varies the speed.
Sep 13, 2016 | Husqvarna Sewing Machines
What to do if my machine is out of time
it needs to be retimed at a sewing machine shop
Apr 09, 2012 | Brother CE4000 Computerized Sewing Machine
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
The needle does not move when the pedal is depressed, though the bobbin wheel and manual wheel do move, could this be attributed to a broken internal belt or?
Have you chosen a stitch pattern and a length, and made sure that the foot control plug is inserted correctely? Make sure your electrical outlet is good also. Good luck
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
Neddle screw wont tighten neddle in
There is a small metal rod about 1/2" long that fits into the hold in front of the screw that holds the needle secure. I didn't realize that I had dropped the rod until I could not tighten the needle. I found the rod, put it into the hole and was able to tighen the needle.
Jun 22, 2009 | Brother XL-5130 Mechanical Sewing Machine
Neddle hitting the bobbon
does the hook assembly move when you turn the handwheel? If no, then your hook drive gears are shot.
Jun 07, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
520 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
