It is getting cross lines in output of the pic in recent days. What may be the problem? Im in karaikudi in Tamilnadu. Where is the nearby service station?
try it on ur game and get rid of the cheat things try it on hers without the cheats and see if it work a try 1 cheat at a time otherwise im not sure cause my game wouldnt load properly but then 1 day it does odd
Yes, the convergence output IC's have gone bad. They need to be replaced. This is a very common problem with all projection tv's. It is the job of those outputs to properly align where the red, green and blue beams land on the screen.
Call Asti flyback replacement company for correct flyback they may have it in stock .number 1-800-221-1828 .ThankYou for using FixYa and Have a Nice Day! If they dont have it in stock let me know .
Wire jumpers need re-soldering....Locations 008,010,017 etc
on inside edge of signal board near convergence IC's.....research
my Toshiba " H " Model rear projection " blows fuses" solutions.
...................................T.
The output freq of the vcr is sitting to close to an rf signal from a digi broadcast i guess,cross modulaion is the term.the rf can be moved away in freq to another bit of band width or if not using rf connection it can be switched off rf output altogether.find online vcr manual and find rf change section
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
